Enable/disable APN: <greyed out unless there are multiple APN's>
Bearer: Unspecified
MVNO type: None
MVNO value: <Not set>
Tap the Menu icon with three dots, then tap Save.
Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
From any Home screen, tap Apps.
Tap Settings > More > Cellular networks.
Tap Network operators.
Wait while the device populates a list of available networks.
Tap the desired network you wish to register on.
Switch 2G / 4G
Tap Preferred network types.
Choose from the following options:
LTE/WCDMA/GSM (Auto mode)
WCDMA/GSM
GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
From any screen, swipe down from the top of the screen.
Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
Tap to turn Data Roaming on or off.
Turn on / off mobile data
From any Home screen, tap Apps > Settings > Data usage.
Bearer: Unspecified
MVNO type: None
Switch 2G / 4G
WCDMA/GSM
GSM only
From any Home screen, tap Apps > Settings >Data usage.
Bearer: Unspecified
MVNO type: None
Switch 2G / 4G
WCDMA/GSM
GSM only
Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
Why don't you ask Boost, then? Those settings are not device-dependent. As soon as you have them, input them via settings->connections. All you should need it
a) the APN of the connection (a name) b) whether they require the use of a proxy b1) if yes, the IP address and the port of it c) whether they require authentication (that's usually not the case) c1) if yes, your username and password
will not work with boost mobile, (even if it is unlocked) you might be able to use it with boost mobile cdma, which uses sprint service. they no longer advertise this service, but still accept new users. give boost a call and ask them for the boost mobile cdma number
