Yamaha HTR-6030 Receiver Logo
A
Anonymous Posted on Jan 05, 2014
How do i turn off the PCM
Im not needing to compress audio files
1 Related Answer
Anonymous
  • 8546 Answers
  • Posted on Mar 24, 2010
SOURCE: no compressed audio on hdmi
You probably need to take that issue up with the setup of the unnamed device originating the signal.
What would the percentage (of a file) need to be for target size if im trying to compress a video around 500 mb to 100 mb? The file turned out to be this big technological issue so smart technological...
no movie file spec told at all mp4?
you can in fact covert any movie made from 1 format to another in 1000s of video editors and endless apps
here come 1000 spam just for you. below , have fun....
why not google this and avoid 12 miles of spam here.
like this, google converter mp3 to
buy video editor and end this.
VUDU has movies in DTS 5.1 but a digital optical cable does not send 5.1 signal to the amplifier
Optical connections will only carry compressed Dolby Digital 5.1, compressed DTS 5.1, and uncompressed PCM 2.0 (stereo).
But your Blu-ray player should have an audio output setting so that master quality soundtracks on Blu-ray (Dolby TrueHD, DTS-MA, PCM 7.1) can be downmixed to DD 5.1 or DTS 5.1.
That way the optical cable will be able to get a usable audio format, regardless of what format of audio you choose from the disc (some Blu-rays do not technically have the older audio formats, they rely on the player to play the backward compatible version that is embedded within the master audio track).
Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
What format does a .mov need to be converted to to play on a DF?
You can try these these file formats and compression rates:
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} File Format: MOV
File Format: AVI
You will have to look for a free video editing software and use it to be able to follow the above formats.
I'm able to hear audio but not the video of wmv files. I have Winamp, VLC player & WMplayer.
Removing the Default Codecs loadTOCNode(2, 'moreinformation'); To remove the default codecs, follow these steps:
  1. In Control Panel, double-click Add/Remove Programs.
  2. On the Windows Setup tab, click Multimedia, and then click Details.
  3. Click the Audio Compression and Video Compression check boxes to clear them, and then click OK.
  4. Click OK.
The default codecs, with the exception of the Microsoft PCM converter, are removed. You cannot remove the Microsoft PCM converter.
uparrow.gifBack to the top Removing a Specific Codec or MCI Device loadTOCNode(2, 'moreinformation'); To remove a specific codec or MCI device, follow these steps:
  1. In Control Panel, double-click Multimedia.
  2. Click the Advanced or the Devices tab.
  3. To remove an audio codec, double-click Audio Compression Codecs, double-click the codec you want to remove, and then click Remove.
  4. To remove a video codec, double-click Video Compression Codecs, double-click the codec you want to remove, and then click Remove.
  5. To remove an MCI device, double-click Media Control Devices, double- click the device you want to remove, and then click Remove.
then download a free codec pack such as k-lite
http://www.codecguide.com/download_kl.htm
and install
2answers
How do i get my video to play....i am following the directions in the book....when i hit play...i get nothing....i am frustrated ....could someone let me know the step by step directions to get the video...
Make sure that you have the correct video format and compression. Video:
File Format: MOV
File Format: AVI
Music:
File Format: MP3
You will need to re-edit the video files you have for the frame to recognize it.
1helpful
Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
