Radius S-3F 4-pin monitor worked fine yesterday but will not show pc data today. I get nothing but a lit blue screen. All self testing data shows up as usual and says it is working properly. I switch to a different S-3F and it works properly on this pc so I know it is the monitor. Does anyone have a circuit diagram for the 4-pin power in. Why won't it display the pc input. Thanks.
SOURCE: KDS radius 17"LCD RAD-7C shuts off during boot and won't come back on (mostly)
I am having the same problem and this seems to be very similar to the problem these users are having but that is a different screen. So I was hoping someone would have more info on this specific monitor. I am seeing no budging capacitors on my boards.
SOURCE: My 195TF is pitch black. Dead or can be fixed?
open the CPU then find the memory and video card then clean both using a paper eraser....good luck....
SOURCE: Hello, I have a Kds Radius RAD-7C monitor and the
6A is OK, HIGHER CURRENT is OK but not higher voltage, the main key is that the pwoer supply MUST be REGULATED power supply. Does it say that on the universal power supply that you have? Basic LCD monitor and LCD TV troubleshooting guides: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.If the new monitor you connected does not show anything either, proceed to Step 6.If the new monitor you connected does show information from your computer, proceed to Step 7.Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.Chances are your original monitor is working fine.Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8 Replace the monitor.
