Fan works but light does not. bulbs are good.
mcdevito75 here, The lights should work from the wall light switch and the fan from the pull chain on the fan itself. The fan and the lights come off the same wall circuit so if the fan works, so should the lights, however in the fan assembly itself 1 wire was for the lights and 1 wire was for the fan. You'll have to pull the fuse to that fan, and remove the cover to the fans wireing at the ceiling., Now you can see the fans wireing, I'll bet the wire to the lights has fallen offf due to the vibration of the fan. Hook up the loose wire and the lights should work. If you can"t do the work, look for a handy man in your building / Area.
