Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later.
STEP 1 : BEFORE INSTALLATION
- If you want to connect the printer 123 HP Envy 5660 Setup to your wireless network, make sure you know the network name and password.
- Connect your Windows computer to the wireless network and make sure the HP printer is compatible with the wireless
- Obtain the network name (SSID) and network passphrase (WEP key or WPA). A broadband internet access is must be used. Make sure you have the USB cable provided along with the printer package.
- Turn on your printer, router, and computer and make sure the computer is connected to the same wireless network you want the printer to connect to.
- If you have connected any USB cable to the printer, disconnect it before you proceed with the software installation.
- Follow the instructions to remove the USB installation if it was previously setup on your computer before you continue:
- Search for the HP folder in the list of installed software programs, click the HP printer folder, and then click 123.hp.com/envy5660
- Once the HP Printer Assistant software opens, click Utilities -> 123.hp.com/setup 5660 & Software Selection.
- Continue to follow the prompts and click Convert a USB connected printer to wireless or Connect a new printer.
- To complete the software installation, follow the on-screen instructions.
- You can also run HP Print and Scan Doctor, an automated tool to connect the printer to your wireless network.
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
- If the printer is not turned on, press the Power button to turn it on.
- On printer's control panel, touch the Wireless icon to preview the Wireless Summary screen.
- On the Wireless Summary screen, touch the Settings icon and then touch Wireless Settings.
- Under the Wireless Settings menu from 123.hp.com/setup 5660, select Wireless Setup Wizard and follow the on-screen instructions to complete the setup.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
- Turn on your HP printer and eject any USB cable if connected to the printer.
- Go to our website and navigate to the download page where you have to download the printer software manually.
- Select your printer model when prompted and then, follow the on-screen instructions to reach the download page.
- Next, to the full feature, click Download or click Basic Drivers.
How to solve HP Printer issues 5X Faster Answer is inside
