Question about Danby DDR583R Dehumidifier
Direct drain Hooked up two dehumidifiers in the basement trying to make sure I hooked them up correctly not draining its filling up the bucket
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
2 possibilities: #1The port that you plugged the hose onto need to be drilled so the water can come out and enter the hose. #2 The hose cannot be higher at ANY point than the bucket. Physics rules apply and the water will always fill the lowest point. Keep the hose low or raise the dehumidifier up.
Posted on Jan 13, 2014
3 Suggested Answers
SOURCE:
  • 82 Answers
SOURCE: bucket fills instead of going down the drain
You may have an unintentional trap in the line (an up and down up and down. Hose has to lay flat on floor to drain.
Posted on Jul 04, 2009
  • 4736 Answers
SOURCE: How do I switch from
Disconnect the hose and reattach the hose connection drain cap, that was removed when the hose was attached. The water will then be diverted into the water collection bucket
Hope this helped you, Tyler and thanks for choosing FixYa.
Posted on Aug 01, 2011
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
I have a drain hose hooked to the dehumidifier, but it still shuts off when the bucket fills up
The bucket should not fill up. Did you remember to take/knock the plug out of the drain hole?
Aug 22, 2009 | Dehumidifiers
Bucket fills instead of going down the drain
Jul 04, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
I have an amana dehumidifier. I have a drain hose hooked to it but it just filled the bucket... it drained fine last year
Check to see if you have a clog in the drain hose from the mold and algae that builds up.
Apr 26, 2009 | Amana Dehumidifiers
Bucket fills up instead of water flowing out hose
There must be a blockage in the hose causing the water to back up and flow into the bucket. Try pushing a flexble peice of wire through the hose to unblock it.
Oct 17, 2008 | LG LHD45EL Dehumidifier
Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Sep 17, 2008 | Kenmore 54701 Dehumidifier
Dehumidifier emptys in the floor.
Check the float first - be sure the styrofoam on the bottom is still intact.  Be sure that you can move it up and down freely (and easily) with the bucket out of the machine.  If that is not bound up, and the foam is in place, next check the switch in the dehumidifier itself.  It's directly behind where the float goes - the way to test it is to turn the dehumidifier on and push the metal tab in with your finger.  The machine should cut out immediately - if it does not - the microswitch needs to be replaced.  (they're very cheap, and simple to replace)
Sep 13, 2008 | Maytag M7DH45B2A Dehumidifier
Drain problem
I have the same problem and after talking (mostly waiting) with Fedders repair, I have been told how to solve the problem. Plug up the drain hole on the right side (the one not connected to the drain hose). The drain hole extends down about 5mm, outside measures 10mm and interior measures 7mm. They do come with a drain hold cover. Not a replaceable part with a number. Off to the hardware store.
Apr 03, 2007 | Maytag M7DH65B2A Dehumidifier
Danby DDR583R Dehumidifier Logo
411 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Sr. Pelo
Sr. Pelo
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
