continuous drain option, So was there a plug in the end of pipe, did you remove it, does your pipe run down over, has to. Not a lot between bottom of unit and floor, But pipe has to go down over, if up and down, will not drain. down all the way
A 48' long piece of garden hose will work fine. Connect the female hose connection to the unit's hose connector and be sure that the hose slopes down and straight to the floor drain. Drainage thru the hose relies entirely on gravity. Be sure to set the humidity extraction level low (32 - 35%) for continual operation.
I hope this helps you and thanks for choosing FixYa..
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
yes, there should be a bucket that fills with water, on the outside of the bucket, there should be a cap you can screw off, once off you can attach a garden hose to that bucket and the other end goes in the drain.
yes jenn when the tank fills it will shut off so that it dosent run all over the floor on many models you can hook a hose on to the tank and find a place to drain itto like a floor drain etc
Check the float first - be sure the styrofoam on the bottom is still intact. Be sure that you can move it up and down freely (and easily) with the bucket out of the machine. If that is not bound up, and the foam is in place, next check the switch in the dehumidifier itself. It's directly behind where the float goes - the way to test it is to turn the dehumidifier on and push the metal tab in with your finger. The machine should cut out immediately - if it does not - the microswitch needs to be replaced. (they're very cheap, and simple to replace)
