If the cycle doesn't complete, check these:
Water-heating cycleTimer
Water-heating cycle
Manydishwashers heat the wash and/or rinse water to a higher temperature,as the cycle calls for it. In these cycles, the dishwasher pauses afterit has filled with water, waiting for the water to reach the pre-settemperature. What happens next, depends, as follows:
- On some units, the pause is timed and the unit continues after the allotted time.
- Onothers, the cycle can't continue until the water reaches the highertemperature. If you have this type of dishwasher and the water isn'tbeing heated (say, because of a problem with the heating element orthermostat), after the unit stops at the heating cycle, it nevercontinues. When you repair the heating-system problem, the "cycleproblem" is fixed too.
Timer
Timersdon't often fail. But if every other part of the dishwasher seems to beworking properly and the timer knob seems to be stuck in oneplace--doing one function continuously--the timer may be at fault.Dishwasher timers can't be repaired. If yours is defective, replace it.
