Dell Dimension 8300 PC Desktop Logo
R
Roy Gehrke Posted on Jan 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove 8300 fan
How to remove the processor fan
Mike
Level 2:
  • Expert 60 Answers
  • Posted on Jan 06, 2014
 Mike
Expert
Level 2:
Answers
60
Questions
0
Helped
15511
Points
104
  • Roy Gehrke
    Roy Gehrke Jan 07, 2014
    The manual doesn't show how to remove the fan ..i'm going to see if i can pop the black 'housing' loose from the case - the grid in the back. that ssems to be the best bet for getting the whole thing out .. to see how the fan is mounted in it. can always glue it back on if the tabs break.
  • Roy Gehrke
    The solution is 2 black tabs on the black fan 'housing' ..gently push down & they release a 'lock' tab allowing removal of the complete black plastic fan housing with fan inside. fan is mounted on some rubber grommet type things.
1helpful
Processors
The Processors should be inter-swappable, both system have a socket 478 on the motherboard.
2answers
No display. Processor fan Blower - active
Identify the pin point of device by swaping of RAM / Processor / and Board.
Then replace / repair accordingly.
Red light on and nothing works
first switch of the computer remove the side covers then switch on the computer and see whether the computer fan is spinning if spinning then remove the memory card from the memory slot clean it with a cloth insert them to the slot and switch on the computer if still not working remove the processor fan and clan the processor fan and the processor with a clean cloth and paste a thin layer of heat sink solvent on the processor and place the fan tightly on the processor if still not working change the processor which is suitable for the socket and see whether its working
The dell dimension 8300 is run in high end then low
This indicates that the Processor is getting too hot. When the Processor gets hot the computer is programed to increase fan speed to cool itself down. To solve this problem you will want to install a chassis fan in your computer's chassis, either bringing freash air into system (intake) or as an exhaust blowing air out of your computer system. Purchase them at your local computer store they are inexpensive and are a great asset to your computer system.
Another option that will help the most is to clean the processor fan of dust. Dust accumulates over the heatsink and prevents the cool air from cooling your processor. Remove the dust with a vaccum cleaner and a paint brush. Do it in a very gental manner as you don't want to damage the fan blades. In some cases it is possible to remove the fan and get at the dust that way.
Take care!
damnor01
Start button amber light flashing.no lights in the back. no sound from pc. It just will not turn on
is the CPU running mine did that when the processor went out also if that fan isnt going try unplugging an replugging it in
I HAVE CHANGED SO MANY POWER SUPPLIES IN MY COMPUTER THINKING THAT IT WOULD STOP MAKING NOISE BUT ALL HAS NOT WORKED AT ALL. (THE FAN OF THE PROCESSOR DOSE NOT MAKE ANY NOISE)IT IS DELL DIMENSION 8300....
is your fan brand new? you can remove cover of that power supply and take out that fan put some lubricant like f2 oil. that brand i use to lubricant on scanner and printer and in fan also.
1helpful
How do I remove the fan shroud from a dell dimension 8300?
there are two clips one on the top and one at the bottom u have to press both the clips and open the shroud.
2helpful
2answers
Computer has shut down and can not re-start
The Dell 8300 does not use industry standard parts. You need Dell specific parts in order to replace the fan. Here is a link to a replacement fan shroud assembly for your Dimension: http://www.discountelectronics.com/index.php?l=product_detail&p=845
You may be able to find cheaper if you do a Goggle search and dig deeper. Hope this helps & please take a moment to rate this solution. Thanks.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
