Even if you think you have a very good battery, it won't make it better.
99,9 % of the time when the camera stops working, before you can make a picture the battery does not have enough capacity. You could try to charge the battery again and again. When a battery is new it could happen it only will become to its full strength after a few charge cycles. Older batteries, will age more when you don't use them, and when you forget to charge them regularly.
If you are using AA batteries, read the following part:
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months can be very long for NiMH batteries.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
AA manganese (Zinc-Carbon) batteries should not be used.
