Question about FoodSaver Vacuum Food Sealer - V3840
V3840 heat strip doesn't get hot
I buy rolls of bags you cut size of bag you want push the seal button then stick the bag in to seal one end then you put in food then put bag in press seal it pulls out air and seals but the heat strip does not get hot enough to melt the bag that's the problem the heating stipe does not get hot I am using food saver bag rolls
    Habit-Forming:
    New Friend:
  • 7 Answers
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
Posted on Nov 20, 2017
4 Suggested Answers
SOURCE:
  • 239 Answers
SOURCE: no suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Posted on Sep 07, 2012
  • 31 Answers
SOURCE: MY FOOD SAVER HAS BEGUN NOT VACUUMING. IT SEALS BUT DOES NOT GET THE AIR OUT LIKE IT USE TO
Does it hum as though it's vacuuming? If not, it's probably broken - the vacuum pump is out. It's cheaper to get a new one than attempt to get the old one fixed. If it hums, then replace any hoses you find or the foam around the drip tray.
Posted on Dec 06, 2014
rgall3285
  • 63373 Answers
SOURCE: Trying to vacuum and seal the broccoli after blanching, cooling and letting it drain. It won't seal the bags. It vacuums the liquid til the tray fills, then shuts off. I start over. How to fix this?
I usually freeze the bag before sealing that way the food is not dry when wanting to use it. pour as much water off as you can tho hope it works for U also I freeze many pounds of fresh fish that way also
Posted on Jul 28, 2015
How do I freeze zucchini
The best way to freeze zucchini is to blanch it first. This allows it to stay firm and green in your freezer bags, while locking in nutrients.
  • Wash your zucchini and remove tops and any bad spots.
  • Cut zucchini into slices or strips.
  • Bring a pot of water to a full boil. Add the zucchini to the water. Leave in for 1 minute only.
  • Quickly remove it, and plunge it into a bowl of ice water. This keeps it from becoming limp and will stop the blanching process.
  • Pat dry until no water remains on zucchini. Excess water causes freezer burn and frost inside your bags.
  • Store in freezer bags according to size you want, making sure that all air is pressed out of the bag before sealing.
  • Mark bags with date, and you are done.
Jul 03, 2014 | KitchenAid KFP760 12 Cups Food Processor
Foodsaver v3420
It's broken, it should heat up and seal.
Contact the manufacturer here: Sites food saver Site
May 13, 2014 | Kitchen Appliances - Others
Not sealing the bag
My husband is a fisherman here in Key West and swears by his vacuum sealer, but he was about to throw it through the window last week when it stopped working.
The motor would just run and run, but the vacuum never kicked on.
I found an answer online that solved his problem and may help some, but not all of you.
Apparently, it was all about bag placement for us.
When you're just trying to seal one end of the plastic to make a bag from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Apparently, the machine was sucking, but air was constantly come through the other, open end.
Once you've sealed a bottom into your bag and have added your contents, then you put the open end (after making sure it's dry) all the way into the vacuum tray.
Hope this helps, good luck! I was so happy to find an answer online that I figured I'd share it with others.
Here's to fresh fish!
Mar 30, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
Foodsaver troubleshooting
The same thing happened to mine and I found a really,really inexpensive way to resolve it. I don't use original foodsaver bags and I found out that their thickness might not be detected correctly so it won't vacuum. To compensate for this, I used an ordinary piece of notebook paper. I cut it to a size of 4 1/2" by 1 1/2". I set the long side in the middle of the liquid catching tray and let it lean back towards the heat strip. Make sure it doesn't cover the heat strip or it won't seal. Now I inserted the bag as the directions say, close and lock the top, and it vacuums and seals perfectly. b40a3e78-1fd3-4c38-9291-c5c4e3885648.jpg
Jan 05, 2014 | Kitchen Appliances - Others
My sleeping bag is really difficult to roll up. Any ideas?
So don't. I almost never do.
More and more folks simply stuff the bag into the "stuff sack" that comes with the bag. You start with the bottom of the sleeping bag and push it to the bottom of the sack, then keep pushing more in. Compress until completed. This saves the trouble of rolling tightly, and also randomizes which parts are most tightly compacted, so you don't compress the filling in the same spots over and over.
When you get home, store the bag loosely in a large box or very large bag so that it can stay fluffed up. (You do hang your bag on the clothes line or tumble it in the dryer when you get home, don't you?)
BTW: I have seen others with this query. What is "difficult" about folding it along its length until it is the size you want, and rolling it from one end?
Oct 20, 2013 | Camping, Backpacking & Hiking
Food saver V485 heat sealer isn't sealing my bags when closing one end to make an bag.
Heating Element / Wire - After heavy use of the vacuum sealer, it is natural for the heating element to break. The amount of seals per sealing wire is dependent on your timer setting, how often you use your vacuum sealer and how thick your vacuum bags are. When you replace the heating element, we usually recommend you replace the sealing strip as well. Different machines have different sizes of heating elements but we carry five stock elements.
This website sells some parts
http://www.elementsandmore.com/foodsaverparts
Nov 22, 2012 | Tilia Kitchen Appliances - Others
Philips food sealer kb1000
First you have to make a bag, so pull from the roll to the size you need, you might want to practice with a small one the first time.
Press the lid gently and the heat light should come on, when it turns green open the lid and you will have sealed one edge of the bag. (usually red means it is heating and green means it is finished)
To seal, place the bag over the vacuum nozzle to remove the air, usually pressing one corner starts the vacuum. When as much air is gone as you want, gently press the center of the lid again, and when the light is no longer red your bag should have the air gone and the bag sealed. DO NOT press too strongly on the center as that will cause the heated wire to cut the bag.
Mar 03, 2012 | Kitchen Appliances - Others
Unit will not heat and Hand free light will not come on.
My husband is a fisherman and swears by his vacuum sealer, but he was about to trthrow it through the window last week when it stopped working.
I found an answer online that solved his problem - apparently, it's all about bag placement.
When you're just trying to seal one end to make a bag cut from a roll, make sure the end of the plastic is just on the front, flat heat seal strip and is NOT touching the black, rubber gasket that lines the vacuum tray, Also, make sure the end is NOT hanging over the gasket and into the vacuum tray.
Oct 24, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
I purchased a Seal-A-Meal roll to make my own bags but can't figure out how to use it. I have a model VS108. Is it possible to seal without vacuuming?
On most models of vacuum sealing systems, you cut off the roll the size of bag you need. Slip one open end of the bag just on top of the heating element over it about 1/8-1/4" and press down the lid to seal the bottom of the bag. Fill the bag and then place the open end far enough into the vacuum cavity over the heating element and close the lid and press down and hold until the cycle finishes. If you don't want a vacuum, just put enough bag material to cover the heating element but not into the vacuum cavity. Hope this helps
Jan 03, 2011 | Vacuums
How do you make a bag from a roll for a vs240
place the end of the roll just past the wire heating element into the sealer and press and hold the lid closed until the cycle finishes. (I usually do this twice in a slightly different place). Remove the roll and cut the plastic back far enough into the roll for the bag you are going to fill. Leave enough space to seal the bag after you have filled it. Seal the filled bag according to the instructions.
Dec 29, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
FoodSaver Vacuum Food Sealer - V3840 Logo
163 people viewed this question
Top FoodSaver Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
