Question about Jacuzzi Home
Model identification Hi, We just bought a house with a nice Jacuzzi whirlpool bathtub and a Jacuzzi steamcabin. Both were built in in 2001/2003. I cannot identify the model/typenumber, etc. Can you suggest a website for me to find out? Thanks, Rolf Netherlands
  • Jacuzzi Master
  • 719 Answers
While the brand of the tub may be of importance to you it may not be important when finding parts for it.
Bath tub manufacturers do not make anything that goes into their tubs i,e. the jets, pumps and controls are all purchased from various Mfg.
Are you have any particular problems with either unit that would make you need the brand of either?
Rod
U S Parts Center
Posted on Jan 16, 2014
SOURCE:
  • 21 Answers
SOURCE: We just moved into a house with a whirlpool
the bathtub needs to be full.  and you can turn the jets on some modles.  old homeowner new this and probably turned the jets up so it will do that not really funny.
Posted on Jun 25, 2009
  • 123 Answers
SOURCE: Does new jacuzzi bathtub nead the heater
Jacuzzi heaters are an addon and are a convnience accessory. They are not required for functionality of the unit. I personnaly do not have a heater in either of mine.
Thx
Deathstalker
Posted on Sep 01, 2009
SOURCE: Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Posted on Jan 24, 2010
  • 1311 Answers
SOURCE: I have a Jacuzzi brand
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Posted on Sep 12, 2010
tunde007
  • 2382 Answers
SOURCE: Kohler jacuzzi, whirlpool bathtub will
Hi, first check the air switch hose that connects to the "button"
Open the access for the pump there should be 1/4" poly tubing (probably clear) that connects to the pump motor. It just slides over a barbed nipple usually located somewhere on the back of the pump housing opposite the pipe connections. Make sure it is in place properly. If it is in place then look else where. The tubing also connects to the back of the air switch "button". This button connection rarely fails, especially if the tub was working and now does not. But if the tub is newly installed and may have disconnected during installation. this connection is probably going to be difficult if not impossible to verify since it is usually concealed after installation.
Some pump motors have resets some do not. If it does it probably is on the very back of pump oppositethe pipe connections.
Also check to make sure that any electrical outlets in the bathroom, or any where in a nearby radius of the tub, to see if they have "GFI" reset buttons and make sure that they havn't tripped by pushing in the button between the plug-ins named "reset". Usually the circuit for the pump will be tied into one of these switches to add ground fault protection to the circuit.
If your pump is not working after checking these things it may be dead. Does your pump "hum" after pushing the button? Do you smell any type oder around the pump that would suggest a "burnt motor"?
If the pump is dead you will have to replace it.
Posted on Nov 07, 2010
Does jacuzzi luxura have a built in timer
If your model has an electronic control then it will have a built it timer program.
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Mar 19, 2013 | Jacuzzi LXS6030 WRL 2HX A 60" x 30" Luxura...
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
The wall switch control for the Jacuzzi bathtub was left on for at least one week. Now the motor for the whirlpool bath will not operate. Could the motor have burned out? Tripping the reset switch did not...
pretty much bet on the fact that the pump has burned out. You are very lucky it did not set your house on fire. There is much friction when the pump is on and there is no water in the wet end to keep the seal cool. You will need a new pump. What model pump do you have? Find your Pump
Aug 15, 2011 | Jacuzzi Home
Jacuzzi doesn't work...no voltage to outlet, checked braker box, reset it..still not working...any ideas?
Maybe a GFCI outlet that it's pluged into may be tripped . check any other GFCI outlets through your house and make sure none are tripped.
Some tubs have access doors with GFCI outlets near motor at tub may be tripped.
May 12, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Need User Manual
Go to Jacuzzi.com and plug in model and serial no. you should be able to find an operation manual there.
Jun 09, 2009 | Whirlpool Caresse 2 Person Bathtub Seats...
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
464 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
