Either a bad thermostat grommet or a bad pour in pan gasket. Either can be found on eBay for cheap. Disconnect from power, take off the top panel. Pour water in to pan and see where water comes from. Thermostat grommet pulls out easily by hand. Pan but must be removed from the tank inlet to replace gasket.
SOURCE: How do you clean out a Bunn VP-17 water tank & line?
I went back and deleted all of my information.
I don't know how you got my email.
I got my issue fixed online chat group.
Friendly people that are genuinely interested.
I did not like that I went through entering all my information
AND THEN you say it will cost $$$$.
I might have signed up if you were 'up front'.
Being 'up front' is also a saying we use here a lot, it means honest.
SOURCE: My bunn leaks at the bottom
A seal/gasket can go bad. If you will get the model and code date and contact customer service, we will be happy to assist you in resolving this problem.
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
