Nail polish remover painted on with a nail brush will most likely do the job. .super glue doesn't like acetone so if that doesn't work paint on acetone very carefully.
I would avoid super glue removal solvent in case the sink is attacked and marked and leave it to time and hot water and detergent to soften and float it away.
If it is common domestic superglue it is unlikely to survive, though specialised industrial products are rather different and more stubborn.
There is nothing to be lost by waiting and if it doesn't work after many immersions and soakings the razor blade will still be there.
Acetone is often found in household nail polish remover, and a small amount on the end of a Q-tip applied directly to the glue should dissolve the bond without damaging the skin. How to Get Super Glue Off Your Skin
Do not use a cotton swab, as this can react very violently with cyanoacrylate
Do not do this on sensitive skin (e.g. lips, eyes, nose) or near an open wound
Just use a razor blade to get under one end of the spill. The superglue doesn't soak in, it just lays on top. You've not harmed anything. It will peel right off once you can get under it.
No damage done my friend. Sure, super glue sticks, but on plastic it just sticks to the surface, doesn't soak in. Just get a razor blade under the superglue and it will peel right off by pulling it.
I am sure that this would help out in a temporary situation but when you are in for a longer drive it can result in a breakdown which you must be prepared of with consequences. Superglue or cement can temporarily seal off leaks but over a time with heat and vibration this can fail. Hence I would recommend that based on the leak , you need to make sure that a proper seal is done even with an externalmetal plugging after a metal paste seal is done which could help out the case.
The glue that attaches that silver plate to the window is similar to SuperGlue, but more dangerous to work with. You can try commercial SuperGlue, but for a permanent fix, you need the glue that windshield repair shops use.
Probably clips are broken...Check with auto body store that has clips . It might be as simple as replacing the clip and snapping the panel back into the mounting hole. It may be a bit tricky so take time to look at how it is mounted. Usually once you pull the whole panel off the other clips will break so you will need a few replacements. Most are plastic and relatively cheap. Super glue will not work.. When it gets cold the glue gets brittle and cracks. That is why panels are held on with clips.
