Engine smoking at bottom of engine oil dipstick. is it dipstick grommet or does the entire dipstick need to be replaced
I would look for other leaks. If you are sure it's leaking at the dipstick tube, there is normally an o-ring where the tube presses into the engine. In general, this is an odd place for a leak, as ther eshould be no oil pressure in the pan (where the tube terminates) and unless the engine is overfilled with oil, the tube end shouldn't be immersed in oil to leak. IF there is pressure in the oil pan, that generally indicates bad rings. I have seen engines where the oil dipstick actually pops out of the tube under pressure when the engine is running due to pressure in the oil pan from blow-by at the rings.
SOURCE: need to replace turn signal switch 93 cadillac deville
First do you have a sterring wheel puller. Can't remove the steering wheel without one. Quite an involved job including snaking the electrical connector end through the steering column. I wouldn't recommend it to the novice
SOURCE: STOP ENGINE-LOW OIL PRESSURE LIGHT COMES ON AFTER INSTALLING NEW
The idle may be to low or the motor is just old and a new set of rod bearings is need with an oilpump to bring the pressure back up.
SOURCE: car is making loud high tone while driving 1992 cadillac deville
your water pump may need to be changed. have a trusted mechanic check it. the water pump is connected to the drivebelt of your 4.9 l engine, and if thats where the sound is coming from you can be pretty certain
SOURCE: I keep getting a stop engine low oil pressure
Just wondering if you put in the correct amount of oil and tightened everything back up properly...
SOURCE: location of oil pressure switch on a 1997 cadillac deville
Oil pressure switches a normally located by or near the oil filter on all cars. :-)
