There are basic wiring details for jbl f5lf-18c807
BL = Blue
N = Natural
BK = Black
O = Orange
BR = Brown
PK = Pink
DB = Dark Blue
P = Purple
DG = Dark Green
R = Red
GR = Green
T = Tan
GY = Gray
W = White
LB = Light Blue
Y = Yellow
LG = Light Green
For more details i suggest click the link below and follow the diagrams that will help.
Victor, unable to locate schematic, links below are a manual with trouble shooting and db's web site to get customer support. press the helpful button and follow me on fixya for more tips and info
run a wire to positive on one coil do the same to negative on other coil then take a single wire and hook the remaining positive & negative connectors together with single wire it should yield a 4 ohm load
you'll need to click on the rating stars to enable the download button, but it's worth the messing around because the file is legitimate. You'll find the wiring diagram on the right hand side of the second big page.
The Trailblazers can be tricky. First off you will need a digital data bus interface inorder to connect to the power locks etc. Try an Omega DB-GMDLBP module or equivalent. You also have to bypass the Passlock 2 system. If you are not a professional installer I highly recommend you letting a pro do this one for you. I cant upload the chart here but you can find it at www.the12volt.com
There is a sticker behind of the radio, but if you don't have radio, here some help:
B+ 1 PK/LB
B+ 12 PK/LB
Panel lamps 3 OR
IGN 2 RD/WT
PCI 14 VT/YL
GND 11,22 BK
LeftRear+ 18 RP/YL
LeftRear- 19 BR/LB
RightRear+ 21 DB/WT
RightRear- 20 DB/BK
LeftFront- 10 DG
LeftFront+ 9 BR/DB
RightFront+ 7 VT
RightFront- 8 DB/RD
