LG DU-42PX12XC 42 in. Plasma HDTV Logo
Posted on May 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not see any screen
Tried to turn tv on with remote and it wouldnt turn on so I hit the power button on my LG could see the power light turn green but screen
Anonymous
Level 2:
  • Expert 187 Answers
  • Posted on May 27, 2009
Anonymous
Expert
Level 2:
Answers
187
Questions
Helped
99165
Points
459
2answers
LG 43LH5000 has blinking green light (power button).
The TV may tell you that you are going to retire when you are old. You need a newer, more fashionable TV set
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
1helpful
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Mitsubishi ws-48413 will not turn on or off. The only sign of life is the green power light stays on and will only go out if I unplug the tv. The green light comes back on as soon as the tv is plugged back...
Https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
1helpful
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
The green light is lit on the TV but the screen is black
Could be a bad powersupply in the TV since you did unplug it and try to start it up it maybe you got a bad power unit inside these can be replaced for under $150. If you Tv is under warranty I would suggest you bring it in for a repair. Thanks for using Fixya.com please hit the ACCEPT button and give a good review thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
2answers
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Green Light on, but nothing working.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#shut_off
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
