Question about Toshiba Satellite C655-S5068 Notebook
Keyboard problems Keyboard doesn't work well
The letters on my keyboard doesn't work
Dust the keyboard to remove any debris.
If that doesn't work, re-seat the keyboard. This requires disassembling much of the laptop. www.ifixit.com has great guides on how to complete this for every model of mac laptop.
Nov 05, 2012 | Computers & Internet
Computer doesn't recognize ez eyes keyboard
unplug the keyboard, go to the manufacturers website and download and install the drivers, plug the keyboard back in.
check your device manager and see what keyboards are in the keyboard section. delete anything but the hid keyboard device and the standard ps2/2 keyboard from the keyboard section. repeat the first set of instructions
if that doesn't work either
take the keyboard back it is most likely faulty
Aug 25, 2012 | Toshiba Computers & Internet
Keyboard problem & it doesn't work prefect
If the keyboard has a round purple connector, power down the computer then unplug and then plug in the keyboard. Power on the computer. If it works your done if it doesn't replace the keyboard. If this is a USB keyboard, with the computer on, unplug and plug in the keyboard if it works great, if it still isn't working replace the keyboard. NOTE if this is a multi functional keyboard (special keys at the top) make sure you install the driver and any software associated with the keyboard.
Jun 11, 2012 | Computers & Internet
Keyboard not working on my Dv9700
Try using a USB keyboard. If that doesn't work, I'll have an indication of possible causes. I want to isolate the keyboard from possible motherboard problems.
Get back to me with a comment because I'm following your problem.
May 29, 2012 | Computers & Internet
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
My two year old spilled water on toshiba laptop which seeped into motherboard. keyboard isnt working...can changing it help solve the problem because when we connect external keyboard while disabling...
Good thing only the keyboard is not working! To answer your question, yes. Changing your laptop's keyboard should fix it. Letting it dry for a couple of days (depends on how wet it go) MIGHT also work. Well, if it doesn't work, just continue with your plan to change the keyboard.
Thanks for using Fixya.
You can rate my answer if you appreciate it.
-damneddle
Oct 06, 2011 | Computers & Internet
Keyboard don't work. It happens 2 weeks ago, now
Is the keyboard working in bios mode? if Still not working. Go to the nearest service center. Tnx
Aug 18, 2011 | Computers & Internet
My keyboard in my laptop is not working.. please help ! it doesn't work at all even the synapse pointing device
Reference the manual on how to remove the keyboard from your computer and than reconnect the cable. If this doesn't work, than the keyboard needs to be replaced.
Jul 03, 2011 | Acer Computers & Internet
My spacebar is not working correctly it sticks and I really have to push it hard for it to work correctly
try flipping the keyboard upside down and see if anything falls out. if it still doesn't work your best bet is probably to just buy new keyboard. they aren't expensive.
May 13, 2011 | Computers & Internet
Toshiba Satellite C655-S5068 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
