you can hook up any equalizer you prefer
In a professional setting this would go after your signal processing before your amp
A consumer receiver functions as both the signal processor and the amplifier in one. Some receivers have a "tape monitor channel", "preamp in and out or "through".
upload a pic of the back of your receiver
I believe your amp has no tape out or any type of feature that would allow an insert. Upload a pic though to be sure.
If that is that case you would have to put it before the inputs, which unless you only have one, would be complicated.
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't. You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Max does recognize receiver over HDMI-CEC. The problem is that DVI output is for video only. Macbook won't (and can't) output audio via DVI. So yamaha receives only video signal via the HDMI connector. You can check that by pressing Option button on yamaha remote and choosing Signal Info - you will see info about video, but no audio signal present.
Hey there fontdude, I will begin assuming you are running your a/v cable into your receiver and then out to the TV or Monitor. If this is the case, I suggest you run the video cable direct from DVD or VCR device to Tv/monitor. You can still run the audio through your receiver. The nature of your problem was probably related to video signal strength being weakened as it ran through your receiver. Good Luck! Let me know how it works for you.
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
