I just bought a 16gb microsdhc card for my G1 and the boune shows that the available sd device memory is 15,318mb, however when i conect te phone to the pc it shows 0mb on the drive. Ane when I put the card directly into my card reader via the adapter it does not register at all. When i put in the 1gb card that came with the g1 it registers inthepc fine. What am I doing wrong, Others have used the same card, what am I doing wrong?
Umm..... did u try formating the card? before you do that backk all info on computer via usb cable. if the G1 says mount to usb go ahead and mount it. in your case it might not work. but try it anyway. if no good goto settings on the G1 then goto SD and internal memory and tap eject SD card then pull it out then push it back into the slot tell me if it works on the PC now.
