I Checked & cleaned filter in front, was not clogged, but got it to spin empty after that. Ran a delicate cycle seemed to work. Now will not wash or spin; starts filling with some water, then indicates the cycle is finished but top of clothes are still wet. Seems to be electrical. Any ideas? Thanks, June
SOURCE: Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below)
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
SOURCE: Error 03 not draining or going to spin cycle. Tub
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the correct
type of soap so the ball check valve on the bottom of the outer drum isn't
getting fouled with excessive suds. Also disconnect the drain hose from your
house plumbing and let it free flow on it's own. This will tell you if the
blockage is in your plumbing and not in the machine.
Pl rate me ‘very helpful’ for the free help!
