Precor 956i Experience Series Treadmill (Used) Logo
A
Anonymous Posted on Jan 04, 2014
How do I tighten drive belt on precor 956i - Precor 956i Experience Series Treadmill (Used)
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on Nov 10, 2014
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514228
Points
111994
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
When push quick start button, why does it display Erro 30 and doesn't run?
Hi There....This is a great message for ALL PRECOR 956/966 owners. This failure usually relates to a "communications" error between the upper and lower electronics. This particular failure is a direct result of a failed IFT drive module, or the lower drive "box" that is made by Advanced Drive Technology. The brains of this lower controller has failed and cannot "talk" to the upper board anymore due to several failed parts inside this box. You are lucky to have this failure arise over a fatal blow-out. Now replacements thru Precor or a distributor will be $550+ and are usually low stock items at places, but you can get repairs and exchanges of this Precor IFT drive by emailing gregATbuyfitnessrepairpartsDOTcom for much less than all other vendors. Currently these IFT drives are 380 exchange and 199 repair and turnaround is one day. Good Luck!
Precor 956i
Sometimes a bad MCB will cause a vibration at certain low speeds. If you have another unit, swap MCBs to verify.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Power keeps cutting out when clients are running on it.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Belts are slipping,
hi,
your treadmill's belt is loose. You have to tight the belt from the both side.
all the treadmills follow the same procedure for tightening the waking belt. Watch the following video for the same.
ok
On my Precor 956 i the Stop Key prompt appears
There is a micro switch under the red "Stop" button. The switch is stuck and needs to be replaced.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
