After moving into house, I noticed that the cooling fan was not functioning. Further investigation showed that it was moving VERY slowly (0.5 rpm) while making a humming noise. I replaced the fan with the identical model and the recommended genuine part. However after fitting the same problem persists. I am not sure what to do next. Could it be the fan timing board? Could it be a blown resistor?
SOURCE: schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
SOURCE: I need an instruction manual for 720EF
Supply me an email address and I will give it the access to my BT Digital Vault so that you can down load the copy I scanned in.
SOURCE: On a STOVES 720EF, How do I Change/Set the Time
I have just uploaded a scanned copy of the Stoves 720 EF manual to the link below.
Requires an Adobe Acrobat reader to view the manual which most computers have.
http://wl.filegenie.com/~simun/Stoves720EF.pdf
SOURCE: I need an instruction manual for a stoves heritage 720EF oven
I have just uploaded a scanned copy of the stoves 720- EF manual to the link below.
Requires the free Adobe Acrobat Reader or similar software to view the manual which most computers already have. The stoves ef720 manual file below is full and free of charge
