Sylvania LC320SLX 32 in. LCD TV Logo
Posted on May 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't program direct tv remote control to the tv
I am trying to program my direct tv remote control RC24 to my new sylvania hdtv Does anyone have the code? None of the code work that I have.
Anonymous
Level 2:
  • Expert 110 Answers
  • Posted on May 23, 2009
Anonymous
Expert
Level 2:
Answers
110
Questions
0
Helped
38105
Points
398
Is there a remote app I can use for sylvania LC320SL1 tv
The Sylvania LC302SL1 is not a smart TV. You can only use an IR remote to control the TV. (A replacement remote is available here: https://www.walmart.com/ip/Replacement-LC320SL1-HDTV-Remote-Control-for-TV-Sylvania-Compatible-with-NH000UD-Sylvania-TV-Remote-Control/511772228 .) Otherwise, look for any universal remote that was programmed in 2011 or later. (Usually it takes 6 months or so for the universal remote manufacturers to get codes for new TVs. The Sylvania LC302SL1 manual has a copyright date of 2010.)
There was a period when some phones and tablets included an IR transmitter. If you have one of these, then look for an IR blaster (TV remote) app on the appropriate store.
I hope this helps.
Direct TV remote
I think you mean Hughs when you're referring to your direct Tv remote? And you want that remote to turn on/off your Sylvania Tv, right?
I'd need to know the Hughs model number on the remote to know if it's a four or five digit code requirement. But here's a site that might help. http://www.remotecodelist.com/remotes/
Scroll down to Hughs and that link should take you to the DTV site where they have a wealth of info regarding codes. Find your model number remote control and you should have a list of possible codes to try.
If all this doesn't work let me know and I'll research sme more.
Good Luck!
Bill
New Sylvainia HDTV/ DVD will not program to the Mediacom remote
hi i used to be an installer for mediacom the remotes will not program to your tv if it is a tv dvd combo
I have a Directv RC24 remote control. I am trying
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Programing one for all remote for a sysvnia model tv ld320ss8
I also own a Sylvania LD320SS8 HDTV. My solution to the
problem of remote codes that won't work is to junk the
Sylvania, and buy a reputable brand TV such as an LG
HDTV which will work nicely with DirecTV or Dish network
remotes.
60helpful
6answers
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
12helpful
8answers
Need code for universal remote Sylvania LC320SL8
We bought a Sylvania LC420ss8 HDTV.
Our current universal remotes would not work, I followed the advice on this site and got a Sony
RM- VL600 Sony Untergrated Remote Commander, use page 16 in the manual to teach the new remote off of the remote that came with the TV. It really works. I am happy with the tv and remote.
Cannot program Direct TV to Sylvania 32"LCD TV LC320SS8
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
here are the code for your tv: Sylvania 10054, 10030, 10171
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
