My iTouch is stuck on a black screen with a white apple logo on it and it keeps loading and then turning off then on again but back on the black apple logo screen.
Solution 1) Press Hold/Sleep & hold buttons at same time for 20 seconds, This may fix you problem.
If problem is still alive follow solution 2
Solution 2) Press Hold/Sleep & hold buttons at same time for 10 sec. & then leave only Hold/Sleep button keep home button pressed & connect you ipod to PC, That means you have to bring your ipod in DFU mode (Recovery mode) Check out this video for getting ipod touch in DFU mode http://www.youtube.com/watch?v=bITIiGswjFI
. itune must be run on PC.
It will ask you for restore. Accept Restore you ipod touch request by itune. Wait for few minutes while ipod being restored.
This process will solve your problem 100%. I have solved same problem for ipod touch. Follow this video http://www.youtube.com/watch?v=AQk4-krrNVk
Thanks.
If my solution help you please vote up me.
To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
iPod touch is not working as expected, it may be due to some of the content synced to it. Try selectively removing certain content that may be causing unexpected behavior such as contacts, calendars, songs, photos, videos, or podcasts.
To remove content, connect iPod touch via USB and use iTunes to change the sync settings. Click on iPod touch in the Source list, and select each tab to change what content is synced then click apply.
If this does not solve your problem, you may need a repair professional. We can help at http://techrestore.com should you need further assistance.
Re-start you device by pushing and holding simultaneosly the "home button" and the "on/off button" the white apple will appear and disappear, then appear a second time- at that point let go of the two buttons and that may solve your problem. I have fixed an IPod Touch that way (-: Good luck!
SOURCE: Apple Ipod 5th gen Not working
have you seen this page?
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
if noting works in the bottom you can see the service assistant.
You will most likely have to get it repaired.
SOURCE: It's all black with a white apple sign
ok try reseting it and no reseting the ipod dose not erase it hold the power and home button at the same time for at least 10 sec or untill the ipodreset it should sjut off and a few sec later you should see the apple logo hope this helps
SOURCE: Ipod touch stuck with apple logo on screen and doing nothing
Open Itunes on your computer. Unplug ipod.
Turn Ipod off (with sleep/wake and home button).
Hold home button down and simultaneously plug in the Ipod again.
Keep holding it (home) until the screen is an apple with a usb underneath it (Itunes sign).
Then in Itunes choose restore your Ipod.
If it's jailbroken, go through the Jailbreak process again.
