SOURCE: Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
SOURCE: drain pump won't stop
that usually happens when there is water in the base of the dishwasher where the motors are. Check to see if there is water in the base. This will trigger a float that turns off the water and on the drain pump.Remove the water and it should fill. However note that water came from somewhere, so find where it is leaking.
SOURCE: Our Bosch dishwasher will not turn on. It appears
check the dishwasher electrical box connection. remove kickplate. box is on r/h side. remove cover. you will probably find the wires and marettes burnt. simply repair the wires. this happens from time to time if the connection is not the best. hope that helped
SOURCE: Bosch dishwasher shu43c07uc/14 dead
Control is available.
There was a recall on control modual because of fire dangers.
Call and get an auth number from Bosch 800 856-9226
SOURCE: Bosch SHU3306UC dishwasher stopped
Make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
