Question about Proscan 32LA30Q Television
Lcd 32" proscan need code for universal remote
Need of code for universal remote for 32" proscan lcd
every codes i tryed didnt work
can any1 help
email me at
camaro022276@yahoo.com
thanks
  • 6 more comments
  • nsummers Dec 20, 2007
    I have the same HDTV with a Brighthouse Universal remote (1056). I have tried all of the codes in the manual and on the website and none of them work. What are my options?
  • Anonymous Dec 27, 2007
    I`ve tried all the codes. how do you auto program the channels
  • Anonymous Apr 08, 2008
    None of the listed codes work and the scanning method does not find the code. CCI6@verizon.net
  • blurgle Dec 03, 2008
    same problem can't find code to prgram this tv  0047 0747 do not work
    any help?
  • olivhoracio Apr 19, 2009
    alguien me puede ayudar en español
  • Anonymous Mar 16, 2014
    need universal remote code for 32 inch LED TV
  • Anonymous Mar 26, 2014
    cant program universal remote
  • Geraldine Summers
    Geraldine Summers Oct 05, 2014
    i ned a code for a proscn tv have the universal romote but no code
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Posted on Mar 17, 2009
The code for Proton works for Proscan LCD televisions. I have 2 codes for Proton 10178 and10466.
Posted on May 30, 2009
Cox was 0030
Posted on Apr 02, 2009
I have a ps32LA25Q. We are having problems also. We cannot find the code key. We have tried many. The t.v. will not show a picture when we turn it on. All we have is audiio. Any suggestion on how we can change this?
Posted on Jan 14, 2008
  • 11,896 Answers
Proscan 11447, 10047, 11347 , 10466,10747 FOR DIRECT TV REMOTE
Programming a Device using Code Search: FOR RCA REMOTE
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
OR YOU CAN GO TO THIS WEBSITE AND FIND MANY OTHER CODES FOR YOUR REMOTE AND TV; http://www.remotecodelist.com/remotes/old-index.html
Posted on May 06, 2009
    New Friend:
Can anyone give me a 5 digit proscan plcd3992a code for the Insight remote?
Posted on Sep 11, 2012
  • lennysdedd
    lennysdedd Sep 11, 2012
I have 2 codes for you compliment of Cox cable, Good luck!
0047
0747
the_lovejoys@cox.net
Posted on Oct 23, 2007
    New Friend:
I had the comcast remote scan the codes for this LCD TV. It got 11356 as a working code.
The downside is that some of the remote buttons, when in the TV mode, would do unintended changes to the TV setup.
Posted on Aug 06, 2010
I have a Proscan tv. I can't turn the tv manually or with a remote.
Posted on Aug 24, 2009
    President:
  • 814 Answers
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Posted on May 21, 2009
    New Friend:
  • 4 Answers
Code 040 worked for Proscan LCD HDTV Model: 37LC30S60
Posted on Nov 22, 2009
SOURCE:
What are the codes for a RCA universal remote for a Proscan 32 inch LCD TV with DVD player combo ?model number three to lb30 QD?
Two possible codes are 000 and 181. If neither works, use code search on your RCA remote to find something that does work and controls some or all functions of your Proscan unit. If a search through all codes stored in the remote fails, you may gave to try a different universal remote. All universal remotes do not store all possible codes.
Apr 26, 2017 | RCA Televison & Video
What is the code to program an iview universal remote 2600 hd to a proscan 32 inch LCD TV model no. 32LB30Q
You can use code search to find something the handles some or all functions. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Mar 13, 2017 | Proscan Televison & Video
I need the code for a universal remote to work with my Proscan tv
Your universal remote has a code search feature you can use to search for an appropriate code for your Proscan TV. If a thorough search through all codes stored in the remote fails, you may have to try another universal remote.
Mar 07, 2015 | Proscan 42LA45H 42 in. LCD TV
Does anyone have the At&T U-verse remote codes?
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
May 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
Feb 19, 2009 | Proscan 47LB45H 47 in. LCD TV
Need TV Code
i believe because this is a commercial television. look at the power cord -- three prongs - right?
I had to get a universal remote and program the buttons manually from the original remote to get it to work.
Dec 21, 2008 | Proscan 32LA25Q 32 in. LCD TV
Codes for remote
I only have a solution for the directv remote codes use the LG TV code 10056.
Jan 11, 2008 | Proscan 42LA30H 42 in. LCD Television
Proscan 32LA30Q Television Logo
18,769 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
