GE 20 CFT GSE20JEWF BB BLACK COLOR SIDE BY SIDE REFRIGERATOR FOR 220/240 VOLTS Special Order Logo
J
Jim B Posted on Jan 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator not cold
Refrigerator side not cold
freddyfox
Level 2:
Sergeant:
  • Expert 237 Answers
  • Posted on Jan 04, 2014
freddyfox
Expert
Level 2:
Sergeant:
Answers
237
Questions
0
Helped
105177
Points
707
You say refrigerator SIDE not cold? You would expect the outside panels of a refrigerator to be around room temperature or warmer as the fridge removes heat from inside the cabinet and expels it outside. If you mean the inside of the fridge is not cold then check the door seals are sealing correctly around the door frame. You could also check that there is nothing inside the fridge protruding and therefore inhibiting the closure of the door correctly.
Frigidaire wont get cold
Hey Rene S, thanks for your post!
In order to reset your Frigidaire refrigerator you would need to disconnect power from it for roughly ten minutes. You can do that by unplugging it or flipping the household circuit breaker. If that does not correct your cooling issue I would recommend contacting a professional to come out and diagnosis your appliance to avoid any unnecessary part purchases. -Matt
Why is the refrigerator side not cooling and the alarm keeps going off
Hello Debby Rhodig, thank you for your post!
Based off the information for your Frigidaire refrigerator I see that your fresh food side is not cooling and the alarm is going off. I would check to verify there is no food or packages blocking the rear vent. If there is nothing blocking the vent place your hand back there to check if you feel any cold air coming out of the damper. If there is no cold air coming out of the damper it could be an issue within your evaporator fan, if there is cold air coming out I would set your temperature to a colder setting.
Changing the temperature inside your appliance can take up to 24 hours to stabilize. If you continue having issues with your refrigerator I would seek assistance from a professional to come out and properly diagnose and repair your appliance. I hope this helps. -Matt
1helpful
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
1helpful
Freezer gets to cold thermostat won't adjust
Prepare to replace the t'stat. At least it is freezing and you haven't lost anything.
Kenmore side by side, freezer section is not freezing. Ice is melting. Refrigerator side seems to be working. I do not hear any noise from refrige/freezer.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
I have a GE side by side freezer/refrigerator. The
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
Side byrefrigerator runs but not cold. Freezer is
take everything out of it, and let it thaw for 24 hours, using towels and whatever to clean up the water......then plug it back in, if it still does it, like 2 days later, it's broke, if it doesn't it was just the coil in the back that froze up. Happened to me.
1helpful
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 • Freezers
Top GE Freezers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
