Acer AL2671W 26 in. LCD Television Logo
Posted on Jan 04, 2014
Where is the screen plnel is localed in acer al2671w hd tv
SCREEN GIVING HORIZANTEL LINES BUT AT THE BACK IS BLUE SCREEN.WHAT COULD BE WRONG AND HOW TO REPAIRE.
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 04, 2009
SOURCE: My AL2671W swit5ches off the backlight before the
I read many postings on this matter and found the solution. Thanks for following up. Kind regards Hans
Anonymous
  • 3 Answers
SOURCE: acer al2671w wont turn on on button turns from green to blue
Replace all caps on main board and preferably the others too and you'll have a nice set again. The set is an excellent design just the capacitors used are not of the highest quality.
Anonymous
  • 1622 Answers
  • Posted on Nov 25, 2010
SOURCE: acer al2671w tv - buttons
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and proceed to the next step
step 2 Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat to click the covers open. This is often a challenge but should not be too difficult.
step 3 Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassemble so re-assemble will be easier.
step 4 Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6 Wash the covers and the buttons
Use a small bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7 Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8 Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9 Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously. Once you have completed test with your camera you can use the remote.
That's it, I hope you got it going again.
Hope this help in solving the problem....
Anonymous
  • Posted on May 22, 2012
SOURCE: I have a AL2671w LCD Acer TV ON OFF switching
Replace C380 and C348 - Done
3helpful
Something wrong with screen
ftp://ftp.support.acer-euro.com/.../AL2671W/manual/AL2671w_uk.pdf
http://www.tv.quuq.org/index.php?ind=tips&op=entry_view&iden=81
http://elektrotanya.com/acer_al2671w.pdf/download.html
Above service and repair manual, above that a forum, above that a user manual, between all these you should be able to isolate and sort out your problem
3answers
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
5helpful
3answers
Acer flat screen tv - sound no picture?
Acer AL2671W 26in problems: (1) sometimes sound but no picture, (2) or screen freezes pink etc. (3) or remote won't turn it on/off (4) or it gives up and says "no signal". Turning it off/on usually solves it temporarily.
Main PCB spare for Acer LCD TV monitor
I have a main pcb from my broken lcd acer al2671w email if interested I can ship it to you [email protected]
3helpful
1helpful
I have ab Acer LCD TV AT3201W and in the manual it says that it is HDTV Ready. What does this mean?
HDTV ready means that your TV is capable of displaying a high definition picture. A standard television broadcast is shown in 480i. High definition starts at 720i. Only an HD ready TV is capable of showing a picture that is 720 or above. So, if a person wants to upgrade to high definition offered by their satellite or cable company, or they want to enjoy a new Blue Ray disk player, they have to have a TV that is HD ready.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Cannot set channels
It is the software or the program that have the TV to operate properly.  Sorry for my english.
Green light but can't turn it on: AL2671W
Sounds like the problem is either the LCD itself or the connection from the circuit board to the LCD. The light comes on, so power is available. The internals of the TV are all solid state (on a circuit board). Because of this, I would not attempt a repair unless you are familiar with electronics and soldering. There could be many problems. I would see about getting an estimate from a local TV repair person and see if they will tell you what exactly is wrong. Also, I would unplug it and open it up to see if there are any loose connections...however, be careful because if there are any capacitors in the circuit, you can get shocked. While inside, look for loose connections or burnt/discolored components or wires. This will give you an idea of the problem. Probably easier and cheaper to **** it up and buy a new one, but you never know...
Blue picture
im having the same problem hvnt figured it out yet, but when you put the screen on warm instead of standard or cold it helped mine,went from blue to not as bad pink .
Top Acer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
