this is not on a Rangemaster, but the principle is the same.
I think, if you have done the other one too, you will have enough information to do this one too. Range Oven Thermostat part WB20K8 How To Replace
for old Rangemasters it is difficult to find the original parts, as they have their outside model.
But when you open the switch carefully, you will find 2 switches on a board, one for the light and one for the fan.
These parts are common for a lot of cooker hoods. The switches look like the one of link 1 Genuine Creda CRV10W Light Bulb Switch Cooker Hood eBay
the second link gives you a complete unit, so the light switch and the vent switch on a board
The same happened to me. I found a 3-amp fuse which I changed, and now it's ok. I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
