Replace the drum and developer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one.
code will remove.
wish you best of luck............
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: Konica Minolta di1611 indicating cof32
ATDC sensor malfunction.Enter in the service mode :
press the Utility key press STOP 0 0 Stop 0 1
select CLEAR DATA then select I/C counter and reset the counter press C.to exit press panel reset.
