LG WM3987HW Front Load Washer / Dryer Logo
A
Anonymous Posted on Jan 04, 2014
LG WM3987HW Filter Assembly defective - LG WM3987HW Front Load Washer / Dryer
1helpful
2answers
My girlfriends LG wm3987hw just lost its power. the outlet is fine. there is absolutely no power getting to the machine. No lights, nothing. Anyone else have or had this problem? Fixable or DOA?
the wm3987hw has an internal fuse located on the "power connection noise filter", It's a transformer or something which cleans up the wall-supplied voltage a bit before it touches the expensive electronics.
You might just be able to replace just the fuse, otherwise the whole unit is part#6201EC1006T, about $50.
take the top off the unit (two philips screws on the top back) you will find the power noise filter on the top inside right wall of the unit. it's not terribly involved to do this fix yourself. 20minute job tops.
Wm3987hw squeaks
Probably a loose or worn belt.
SMART SENSOR SAYS CHECK FILTER BUT THERE IS NOTHING IN THE FIRLTER
It could be the vent hose in the rear is constricted. Check to make sure all hoses going in the rear are in good shape. Nothing constricted, nothing pinched, etc. If it's not that, check to make sure they aren't clogged.
3helpful
2answers
The washer will not turn on. It ran a load, but did not finish drying and would not turn on. I have tried to reset it via: unplugging it for a few hours, and spinning the drum, but it still will not turn...
I follow this advice without checking any other components. It was a bit of a costly and timely mistake. Not to say this is not a good solution but before swamping your "control board" (about $99) please check your Filter Assembly aka Noise filter (i got mine from Appliance Parts Pros it was $27.78 much cheaper and it seams like it may be a defect just because they have redesigned the part now.) I am attaching some pic that i took so hope they help u tell if the part that is in your machine is bad or not and to help replace it if needed.8_27_2012_3_54_14_am.jpg8_27_2012_3_54_40_am.jpg8_27_2012_3_54_55_am.jpg8_27_2012_3_55_51_am.jpg8_27_2012_3_56_01_am.jpg8_27_2012_3_56_16_am.jpg8_27_2012_3_56_29_am.jpg8_27_2012_3_56_39_am.jpg
Hope this helps anyone out there having an issue with there LG WM3987H or WM3987HW Washer/Dryer combo that will not start up. I was not getting any light no sounds or any type of response form my W/D combo when I hit the on off button or any other button on the combo. A very helpful link I found was http://www.youtube.com/watch?v=ABbLk_IXLLI it help me to be able to tack a part my combo.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
