Master
- Posted on Feb 13, 2015
Re: Name and passsword belkin f7d1301
- Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
- Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
- Username: admin
- Password: password (case-sensitive)
- Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
- On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
- Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
- Wireless Gateway 1 customers, click EDIT at the right.
- Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settingsname and passsword belkin f7d1301 - how6361image004.png
- Check the box next to Show Network Password. The Network Password (Network Key) will be displayed aboname and passsword belkin f7d1301 - how6361image005.pngo write down this information.)
- On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
- Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
- If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
