Computers & Internet Logo
f
fonda jefferson Posted on Jan 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magicjack problems i am trying to connect the fax. please help
Dayton Computer
Level 3:
  • Master 1,640 Answers
  • Posted on Jan 05, 2014
Dayton Computer
Master
Level 3:
Answers
1640
Questions
0
Helped
819186
Points
6396
Fax communication is the same as Voice Communication when using the MJ. It dials in the same way. If you do not FAX using your Printer Fax line into the MJ; you must use a FAX mailing program generally a part of word processing such as Office. You would need to do a setup in Word for example to call out via the Fax Number. If you use a FAX (Independent) machine, connect the line out cord from the Fax Machine into the MJ and dial out from the FAX device. Check to see if you have a Dial Tone? If Not, the MJ is not open and working.
2helpful
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
How to recieve fax without phone line
It should work fine.
Plug your fax machine into your magicJack, just as you would normally connect your fax machine to your telephone jack.
IMPORTANT!! If your magicJack is connected to your computer, make sure that "Normal (Hi-Speed)" is selected. Your fax machine will not work if you have selected "Air Card (3G)".
2helpful
I have a Cannon MX860 all in one machine. I have tried sending a fax multiple times with different baud rates down to 7200. The other machine answers and the two begin negotiation and the speaker goes...
its not the printer but magicjack. I have the mx860 its great but magicjack stopped supporting fax after an update came out. mine used to work great, but then just stopped after no change on my end
Faxing with magicjack
Magicjack says that you should be able to use your fax machine if it is plugged in first to the magicjack socket, then plug the phone into the fax machine.
1helpful
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
2answers
How can i use my fax with magic jack.using lexmark X2350
This is the answer that I got from the FAQ page.
SOMETIMES.
We do not officially support using faxing with magicJack.
Please try the following steps to use magicJack with your fax (contact your fax manufacturer for details):
  1. Turn off error correction on your fax machine or program
  2. Set the fax machine or program to use the slowest speed available
  3. Increase the speed, checking at each speed that faxes work
It seems that it depends upon the faxing unit that you use.
12helpful
6answers
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
1helpful
I have my fax machine hooked up through a magic jack. how do i change fax speed?
I contacted the folks at MagicJack today and for faxes they confirm your findings. They suggest the following: We do not officially support using faxing with MagicJack. Please try the following steps to use MagicJack with your fax (contact your fax vendor for details):
- turn off error correction on your fax machine or program
- set the fax machine or program to use the slowest speed available
- increase the speed, checking at each speed that faxes work
The change must come through your fax machine, not the MJ.
HERE is a link to the manual for your fax machine.
If you are having problems sending or
receiving a fax due to possible interference
on the phone line, we recommend that you
adjust the Equalization for compatibility to
reduce the modem speed for fax operations.
a Press Menu, 2, 0, 2.
b Press a or b to choose Normal (or
Basic).
�� Basic reduces the modem speed to
9600 bps. Unless interference is a
recurring problem on your phone
line, you may prefer to use it only
when needed.
�� Normal sets the modem speed at
14400 bps. (Default)
Press OK.
c Press Stop/Exit.
Note
When you change the compatibility to
Basic, the ECM feature is only available
for color fax sending.
There are only 2 speed settings. Since the MJ does not support faxing, if the slower 9600 bps does not work, you will be unable to fax with the MJ.
Thanks for using FixYa - A FixYa rating is appreciated!!
Can I connect my HP 3055 to magicjack for faxing
Sure you shouldn't have any trouble doing that. I'd say a magicjack.com would be cheaper than voip since it's 20 a year.
Grand Canyon Tech
Grand Canyon Tech
