If you are using a Micro sd card you will need a Sandisk sd card that says sdhc nothing higher the class 4 sd card which is the speed of the card. If still need help call Moultrie with equipment to troubleshoot the number to call 8006533334 option 1 and 1 live person
My wife has this problem cuz she doesn't know the cameras outo focus if the thing she covers with her fingernail when she goes to take a picture. If your lens is clean and there is light then the camera is in focus some where even if not where it is supposed to be and you can figure that out easy. Take a measuring tape and extend it to 20ft (optical infinity) on the sidewalk then take a picture of the extended blade from about 6 to 12inches off the ground. You will see where it focused. now you can set a stuffed animal anywhere along the tape and test the auto focus. Half press of the button ( watch the fingers don't cover the sensor or the emitter. :-) Oh, if this doesnt work then you have purchased a camera that was dropped when it was open and damaged the alignment.
Try to set the camera mode in to auto Make sure the flash is set to auto Take pictures in different lighting condition outdoor and indoor Try do transfer pictures in the computer format the memory card and the internal memory If the pictures appears blurry the lens assemble on the camera or the sensor is defective...
look kindly set ur jog dial to AUTO if problem persists then it might be a CCD FAILURE it happens in that , Yellowish Pinkish or Redish Tones , Streaks , Blank pics , Over Exposed pics all are syptoms are of CCD Failure !
if after the AUTO settings it persist then contact FUJIFILM it is a known problem in thousands of cameras they will do it FREE REPAIRS even if u are out of warranty dont worry just call them see a link for this problem this problem is active in new models as well KINDLY RATE ME WELL ! http://www.imaging-resource.com/badccds.html
There are 3 flash settings for your camera. While you are taking pictures, you set the flash by using the 4-way directional pad.
Push it to the right and make sure the setting shows a down crooked arrow with a circle around it (off), or, to where is says auto. In auto mode, it should only fire if it needs the light.
Thanks for coming to FixYa, and don't forget to rate my answer.
Press [MENU - SET ] to display the [SETUP] menu
and select [RESET].
The [REC] or [SETUP] menu settings are
reset to the initial (factory) settings.
You can download the manual following the link below:
http://service.us.panasonic.com/OPERMANPDF/DMCTZ1-MULTI.PDF
I've seen some of those white eyes photos.
Some are down right scary.
I'm sure you have encountered red-eye when taking flash photos of people.
With some animals, it is not red - but white.
Try to catch the animal looking away from the camera when you take that flash picture. Have someone distract him/her.
Fixing Demonic Pet Eyes
http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Fwww.myjanee.com%2Ftuts%2Fpeteyes%2Fpeteyes.htm
http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Ftlbtlb.com%2Ftlbimages%2Fmax2.html
