Sharp 4501N - Need to know how to fix this problem,
CE-00 means the copier cannot find the computer or server it's directed to scan to.
The usual cause is that the IP address for the scan destination has been changed by DHCP and the connection info has not been updated in the copier.
To resolve, reboot the destination workstation or server. Or, right-click on the Network Scanner Tool icon in the tray, select Automatic Profile Update, and click on Update Now.
If the scan profiles were created in the webpage and not through Sharpdesk/NST, make sure that destination names and/or IPs have not changed in the profile.
If you are using DNS name resolution instead of direct IP addressing, you must be sure that the DNS server IPs are correctly entered into the web page.
Hope this helps!!
I get a ce-00 error. was working until recently (before weekend). I need to know how to setup scan to email function in sharp mx-m700n multifunction machine. I have some questions about this. Our old website and hosting we did not renew but this went down a couble weeks ago, does this have anything to do with that? I need to set up this to scan to email.
Optional Information:
Make: Sharp
Model: MX-M700N
Already Tried:
Unplug, redo static ip, called cable co to verify it was correct. Tried to use static ip. I can access the device through the web using its static ip but cannot get the scan to email to work.
Forward your complain through this link: http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
If you dont get the help to solve the error issues then please forward the full Model Number and Specifications here for further assistance
CE codes relate to the sorter / Finisher.
Check the sorter for open covers or anything out of place.
Check the sorter connection to the copier.
Hope this isof some help.
Ed
