Nokia N73 Cellular Phone Logo
Posted on May 22, 2009
Nokia n 73 signal disappear
My nokia n 73 signals disappear and 3g icon appear in signal bar
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on May 22, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1654
Points
16
Sounds like you're getting 3G interference. It happens because you're just on the edge of a 3G area. The same happens to me on both my N95-8GB and N73. The phone is detecting a weak 3G but it's not enough to make a call.
You need to go to "Tools" -> "Settings" -> "Network" and switch from "Dual mode" to "GSM" The phone will say it needs to restart, select "Yes"
The phone will then restart and you shouldn't suffer any more 3G blackouts.
Hope that helps.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
435
Points
Nokia 1280 no signal what
parablum
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 03, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
464
Points
0
Your phones ic is not usefull pls change that in a service point
How do i get my sprint phone to work on wi-fi ?
sprint phone or samsung ?
Sprint offers high-speed WiFi service for existing Nextel customers, and provides an extensive network of hotspots in the United States at locations commonly frequented by business travelers, such as hotels, airports and conference centers.
Getting Sprint WiFi requires a Nextel customer account, connection-management software, a MyNextel user account and a computer that supports high-speed broadband.
Sprint WiFi plans include an unlimited WiFi hotspot and an unlimited PC access plan with a WiFi hotspot package.
Sign up for WiFi service through Nextel by calling 1-800-SPRINT1.
Download and install the Nextel Connection Manager software.
Nextel offers the WiFi version of the connection-management software at the Sprint Nextel website (see Resources).
Register your account via MyNextel on the Sprint Nextel website (see Below).
http://ortshop.sprint.com/en/solutions/dataaccess/connection_manager.shtml
Samsung Epic 4G Phone into a Wi-Fi Hotspot
The Samsung Epic 4G smart phone allows you to convert your phone into a Wi-Fi hotspot and connect up to five devices.
Such a set-up will keep you from running around searching for an area that offers free Wi-FI. If you're stuck in an airport or staying overnight at a hotel, you won't have to pay extra for Internet service.
You can connect your laptop or other media device to your phone's Wi-Fi network.
Press the "Home" button, which looks like the outline of a house, on the bottom of your Samsung Epic 4G phone.
Click the "Menu" button to the left of the "Home" button.
Click the "Settings" icon, which looks like a gray box with a spoke in the middle.
Scroll through the list and click "Wireless & Networks."
Press "4G" until a check mark appears, indicating the 4G network is enabled.
Click the "Home" button.
The 4G icon will appear to the left of your signal bars in the upper-right corner of your screen.
The separate sets of bars above the 4G logo indicate the strength of your 4G signal.
When the bars above the 4G logo are completely gray and the 4G logo is white, you have a weak signal.
When you are no longer receiving a 4G signal, your 4G logo will be gray and a 3G logo will appear, indicating that the 3G network is now enabled. If both of the logos disappear, you are not receiving any signal.
You must have either a 3G or a 4G signal to use your phone as a Wi-Fi hotspot.
Enable Sprint Hotspot
Press the "Applications" icon, a blue box with four whites squares in it, in the lower-right corner of your Samsung Epic 4G phone.
Press the "Sprint Hotspot" icon, which looks like a phone with two signal bars on the right side, until a check mark appears to the right of the icon, signaling the Spring hotspot function is enabled.
A pass-key allowing you to connect other devices to the phone's network will appear on the screen.
Write the pass-key down.
Enable Wi-Fi on your laptop or other device that you want to tether to your Samsung Epic 4G phone.
Search for the Wi-Fi network affiliated with your Samsung Epic 4G phone.
The name of the network will begin with "SPH-D700XXX."
To change the name of the Wi-Fi network affiliated with your Samsung Epic 4G phone, press the "Menu" button; the "Settings" icon; and "Device Name." Enter the new name for phone's Wi-Fi network.
Click the network affiliated with your Samsung Epic 4G phone on the device you want to tether to your phone'ss Wi-Fii network.
Enter the pass-key, and click "OK."
Your device will now be tethered to the Wi-Fi hotspot on your Samsung Epic 4G phone.
11helpful
2answers
I have nokia 5800 xpressmusic phone. i wanna activate 3G on that. it shows the 3G icon but no signal my question is how to activate 3G thank you
i have nokia 5800 xpressmusic phone. i wanna activate 3G on that.
1helpful
Hi sir i have nokia n73 and i there is screen problem with my nokia n73 on the top of screen (where signal and battery bars presents)there is an icon named 3G appearingand my phone will not be having...
3G simbol comes when we get rid of range,and if you want to get rid of that message goto settings>network>operator>network gsm only
thanks
Jul 29, 2010 • Cell Phones
Nokia n70 does not show 3g icon
The 3G icon appears only when you are in 3G reception area and you are receiving 3G signal.
Ensure that you are in the 3G reception area and signal is received .some areas there may be weak signal it may also cause to select Gsm mode
3helpful
2answers
My N79, got wet. Only Network connection problem.
clean your phone with alcohol,thinner or ipa liquid. Give more attentions to signal section parts,especially to water damage parts.
1helpful
Video call doesn't work
For video call to work, you have to be in a 3G covered area. This means that the icon over your signal level bar must be full and have 3G written in it. It wont work if it is running on a low 3G band (the signal bars must be full) a GSM band (a G logo above the bars) or HSDPA band ( a H logo above the bars).
I don't know why even though HSDPA is faster than 3G but the viewty will only allow video call to take place when 3G is available.
I've heard it can also be dependant on your service provider, as PAYG sim cards sometimes wont allow video calls.
1helpful
Can anyone explain this icon that has appeared on my phone after my grandson was playing with it it has a letter G then a bar with sides and an upward arrow
do not worry. your grandson has caused no problems. this refers to the type of signal you are currently recieving. This icon means "GPRS" signal which, for lack of a better term, means you have a stronger signal than if you saw the letter "E" in its place. the timing was most likely coincidental.
2helpful
2answers
Letter h
i have that one too.. yes, it stands for High-Speed Downlink Packet Access (HSDPA) for a 3G mobiles. i had network problems/signal issues weeks ago when i used that setting, so i changed my phone setting from 3G to GSM. [uhm..i don't think you can find that in the user guide either, hehe. you have to browse and make yourself familiar w/ your phone=) ] with that i don't think i can make video calls, but who cares.. my signal issues were resolved. now, whenever i switch back to 3g, i can still see my signal bar on the upper left fluctuates.. sigh ;c
anyways, you can make that "H" disappear by going to:
settings=
connectivity=
mobile networks=
gsm/3g networks=
then choose GSM only.
3helpful
Voice message icon keep appearing
dear reset the phone
switch on the phone and type *#7370#
set will ask the security code (12345 is default)
type it that will reset.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
