System just won't print, I've turned it off and back on, nothing but loud clicking...........
I had a similar problem. I replaced all the ink cartridges and cleaned the printer. I checked the nozzles to be sure that they were clean and cleaned the area where the cartridges set. It took a little while but my printer is working again. Mine makes a clicking sound after you push the copy button but still pulls the paper through. Does yours pull the paper through at all?
when i turn on the the mp530 it goes through initialisation and then makes a click to release the output and then copy and alarm light flashes on and off in 12 flash cycles. the pc shows an error 5c10
showing 5c10 error code
How did you clean that? I see that the ink is actually spilled a bit, where the cartriges are, but basic leaning doesn't help. I'm getting the error again.
