Honda 6370C - Parallel Power Kit For  EU3000i Logo
Posted on May 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honda eu 6500 gen overload indicator light will not shut off
Brand new generator first day ran 6 hrs worked great ran skill saw and small compressor. Next day connected 18 volt cordless tool charger and also car battery charger at same time after 5 minutes power overload indicator came on and all power outlets quit working. I shut off machine disconnected everything but light stayed on. I waited a day tried again as soon as generator started overload light came on and no power available.
Does anyone know how to reset power overload indicator without going to dealer. Generator is in a remote location.
  • Anonymous Mar 16, 2014
    Overload light comes on then moter will stall,can anyone please help me with this problem
Vitally Alcher
Level 3:
  • Honda Master 1,645 Answers
  • Posted on May 22, 2009
Vitally Alcher
Honda Master
Level 3:
Answers
1645
Questions
Helped
467375
Points
3209
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Dometic AC B59516.711 15,000 BTU, while on generator power the AC works during day while it hot but once the sunsets and it cools down, compressor kicks on it drags the gen down and shuts it off.
something else besides the ac is stopping ( overloading) the genset
if it works well during the day, the compressor has to be working so the ac is not the problem
a 4000 watt gen set has a duty cycle load of around 3000 watts full time so any additional power requirement besides the ac will overload it
electric stoves , microwave ovens , hot water elements , anything that consumes power after dark will when combined with the ac will overload and shut down the gen-set
3answers
When I plug in a tool, it runs fine, when I plug it into my house with the breakers all off, it blows the breakers on the generator? My Honda 2200 watt works fine this way?
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
Does the yamaha EF1000is inverter generator 1kva
it seems to be the standard that the rating or model ??1000 or ??1500 or ??2500 or ??5000 or??5500 or ??6500 is the kv rating of the gen-set regardless of straight or inverter
so if yours is EF1000 it will be 1000 watts or 1 kv
remember that most electric drills are 1000 watt units so a unit this small is mostly good for lights, charging batteries, small compressors for tyres
Why does Honda 3000 spark plug breakb down after about 8 hrs of run time? Total hrs on gen is 95
some units may have a temp sensor located on the cylinder head that may shut the engine down before it reaches the required temperature.give me the model if possible.
Honda eu 6500 Error e21. First time using it and the machine is new. How to fix it? Sorry there wasn't category for generator
check oil levels as generator will not start if oil level is low. this is a built in safety device on most generators and one of the leading causes of returns to stores />
Aug 03, 2013 • Garden
Portable generator stalls when load applied
Connect the air compressor to house plug and check amp draw with tester. More than likely you will find that the initial start amp load is too great for the generator. Do not rely on the information stated on the compressor. Generators and air compressors do not get along. At our repair shop, we find that most contractor /construction type generators that were used for running air compressors had failed or leaking capacitors and were not producing correct amount of power. You could have gen set with weakened capacity and air compressor that is drawing more than stated on plate. Good luck
Mar 08, 2013 • Hammering
1helpful
6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
1helpful
BRAND NEW GENERATOR NO POWER
tim n tennessee ...if the gen. runs fine and generates no power...:
1- check brushes.
2- check wireing.
3- check AVR card.
if u have any further questions email me at [email protected]
Refrigerators not cooling
no reset but the frigs do have overload circuit that will shut compressor down,the frigs. compressors need a certain about of amps to start and to run ,what is the amp rating on your generator?let me know-mike
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
