SOURCE: How to remove the outter door frame on the GE Microwave
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
SOURCE: Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
SOURCE: GE SPACEMAKER JVM1650
When door open the microwave should not work at all, if the turntable and light come on with the door open , if they do , then this is an additional problem with door switch and must be fixed.
Regarding humming noise and no heath, Test the high voltage capacitor,
the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed
discharge before testing, or you risk to get electrocuted, even if
power is off. Capacitors can get discharged by shorting their two
contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
SOURCE: Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the process to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
