Question about Karbonn K9
Insert memory card
Memory not work
When memory card is inserted the camera wont work
You can insert CF memory and some memory stick cards when you use a special adapter. When you use a memory tick, make sure it is compatible, because the memory stick is the most incompatible memory card, if you have not the correct one.
When you use a CF memory card, check all contacts. Not one contuse pinn in the camera should be belt a little. Use a bright light and a loupe to check.
Feb 13, 2014 | Sony Alpha DSLR-A350 Digital Camera
I am getting no memory card inserted
Remove your battery
insert your memory card
insert your battery
Power On.
if still no memory card inserted
Replace your memorycard
something wrong with your memory reader (parts of cellphone)
Jan 19, 2013 | Nokia N73 Cellular Phone
My phone wont read my memory card
dear, Memory cards dont work in 3 cases.
1. You must be putting a memory card over the limit of your mobile.
that is if your mobile only supports 2gb card, then you must be inserting 4gb card then obiusly that will not work.
2. You must be inserting a broken or cracked memory card.it will definitily dont work. Throw it!
3. You must be inserting a currupt memory card, try formatting it in some computer, if still it dont work then it is useless. Throw your card.
memory card carry only these 3 problems, if non of those work then i am sorry!
regards!
Jul 30, 2011 | Samsung Star GT-S5233 Cell Phone
My mobile displays no memory card inserted when there is one
May be memory card is not inserted properly, plug it out and insert it again. and switch off and then do on your phone.
if not working by doing above...
Then there may be memory card problem, or format of memory card not supported by phone...
Do a memory card format using your PC, format it with NTFS file system. and then insert it into your phone it may start working...
Thank You
Apr 16, 2011 | Nokia 5800 XpressMusic Smartphone
When i insert my 4 gb micro sd card into my celfone and i set to external memory, it flashes insert memory card. Just after it was inserted into a wrong slot in other celfone.
Hello Sir !! Welcome to Fixya !! There are two possible reasons for this error.Either memory card is corrupted or your cell phone memory card slot is got damaged.
  1. IF your memory is got corrupted then you can troubleshoot your memory card by inserting in another phone.If it is not working then your your memory card is got expired.There is nothing you can do.
  2. If your memory card is working then your phone memory card slot is damaged.You can get it repaired by your nearest customer services center.
If this works for you.Then please rate or token of appreciation will be esteemed. Rizwan.
Mar 29, 2011 | SanDisk 4GB microSD High Capacity Memory...
I will put memory card in my mobile no memory card inserted
First of all,make sure that you're inserting the approved type of memory card.
According to nokia company,nokia N70 supports for RS-DV-MMC cards.
If you're using the correct card,make sure the card is clean enough.You can clean the card by using a soft dry cloath like cotton cloth-DO NOT USE ANY LIQUID-.
After doing so,re-insert the card and check.
If the above step doesn't helps,insert the cleaned memory card into a card reader and check whether the computer can open the card.If it can,backup all the data on the memory card and format the card.Then insert the card into the phone and do a format to the card againg via phone.After that you can restore the data back to the memory card.
If all the above methods didn't work,then may be your memory card is burned out..
Jan 11, 2011 | Nokia N70 Cellular Phone
5800 MMC NOT WORKING
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
To test if it is the memory card
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Jun 18, 2010 | Nokia 5800 XpressMusic Smartphone
Message says - memory stick not inserted
Dear,just format the card with computer through a card reader and insert the cardinto fone then format the card by ur fone and then check, if problem presists then ur fone's card jacket is not working so then you will need to go to a certified mobile fone repairer to get changed your fone's jacket. its not very expensive..thanks
Apr 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
Get Memory card not inserted
simply check the memory card through card reader if it works then u have to check the socket of phone where the card is to be inserted..
that one is causing problem...may be its pins are not propely being connected with the memory card..
if  the card doesnt work even with memory card reader then the card is faulty...or if u dont have memory card reader just put your memory card in another compatible phone to check..
or get another card and put it in your phone for checking..
hope it will fix the issue so dont forget to rate it...
Jul 06, 2009 | Nokia 5800 XpressMusic Smartphone
My computer cannot see my 8gb sd memory stick even though the reader is working it keeps asking to insert a disc
chek the memory card is not insert properly in the card reader , first u properly insert the card into the card reader and then check
Jun 08, 2009 | SanDisk 2GB microSD Memory Card
Karbonn K9 Logo
Top Karbonn Cell Phones Experts
boca
Level 1 Expert
nelson crespo
ray gallant
ray gallant
Are you a Karbonn Cell Phone Expert? Answer questions, earn points and help others
