I have tried 3different fairs of headphones but for some reason whenever I plug any of them in, I can't hear the track I record or, well, ANYTHING! All I hear whenever I press play to listen, is fuzz, like the nise your tv makes with that dotted gray and white screen you get when hu don't have that channel.
SOURCE: No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
SOURCE: Numark cue mixing
to change headphone track, use the cue slider which is located on the right of the control panel above the right chanel treble control and below the cue gain control. chanel 1 or 2 can be selected or in the middle for a mix of both tracks just like the cross fader.
SOURCE: Tascam 238s - bad recording track
Hi Folks, I think the problem on Tascam 238S-Decks
are bad cheap electrolyte Capacitors. Acid gets out an destroys the solder points and PCB tracks.
I found some smeary liquid an the PCB, where it is affected.
You also find bad leaking caps on the Korg workstation W/01-fd.
good luck, Jo.
SOURCE: Prosound MMX 410 DJ mixer. Cueing a track
Select the channel you wish to listen to on the headphone select switch and turn the volume up.
SOURCE: Hi, I have an HHB
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
