The door handle on our kenmore above stove microwave pulls out at the bottom. the top is still connected. Can't seem to see how to get into door to see if it came unscrewed or do I just glue it?
Loose bottom hinge - slide the microwave to the edge of the counter, and look at the bottom hinge - you may have to remove something to see clearly. Its likely you are missing a screw or the screws have worked themselves loose.
I always recommend
that you use the vent fan whenever you're cooking on the stove
top to keep heat, steam, and
grease out of the controls and door panels.
One quick way would be to look on the top of the unit. Do you see empty screw holes where the screws going through the cabinet above it will go through and screw into the top of that unit? If no open screw holes on top of unit probably not an over the range model. Also, look under the bottom of the machine. do you see feet??? Or just aluminum screen vent filters. If feet and no filters probably a counter top unit.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
From the service manual:
Door Disassembly
1. Disconnect power to oven and remove oven door, (see "Door Removal" procedure).
2. Pry away choke cover, by placing a tool in the upper right corner of the door and gently prying outward on the choke cover. Continue to work around the door casing until choke cover is completely loose.
3. Slide latch assembly upward and to the left to release plastic tabs from door frame. Once latch assembly is loose the spring may be disconnected from the door frame.
4. Remove screws securing door handle and door frame to door panel.
5. Remove door frame by releasing tabs around entire door panel.
Remove door handle by placing a hand on door panel next to the top of the door handle. Twist door panel towards the inside of door and pulling on the top portion of the door handle in a quick jerking motion.
NOTE: When replacing door handle, the bottom portion of the door handle must be inserted first.
You can find handy exploded views and order parts by model number here.
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad. On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful). and put screws at the bottom
MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
Take the glass tray out and unplug it. Remove the 2 or three phillips screws in the top of the cabinet going into the micro. They should be towards the front. Hold up on it while removing screws. When all screws are out, let it tilt forward and lift it up off of the hooks. Some require help, so be carefull and put blankets on your stove to set it on when it first comes out.
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service.
Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced.
The handle by itself about $40, apparently GE doesn't know how to
make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want!
All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in
place). To get to the 2 screws that anchor the BOTTOM hinge, simply
remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel.
Once you've removed the 5 hinge screws, the door should pull pretty
much straight out.
Reverse the procedure with the new door, which should come with hinges attached.
Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe.
Good luck
