Cars & Trucks Logo
Posted on May 21, 2009
Chrysler neon 1997 chrysler neon 1997 radio and interior light no
I have just taken out neon radio and put in my sony but now radio and interior light are not working. i have checked all fuse's and they r ok.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on May 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1936
Points
11
What is a body control module for a 1997 Chrysler Town&country
a body control module(bcm) is used to control radio, a/c heater control, interior light system, power windows, power door locks.
2000 Chrysler Neon interior lights wont turn on.
Time delay relay is the relay that allows the interior dome light to remain on for a brief time when you enter or leave the car.Usually the lights will remain on for a few minutes and then dim down and finally off.
It sounds like the daytime running lights were put on that circuit and the relay removed to keep them on constantly.
This sounds like a time and material repair that a shop will have to do. Tracing the wiring installed by the previous owner may be required to find out what was done.
2answers
1990 new yorker. fuse for the dash lights,radio and dome ligjts keeps blowing
there might be corrosion on the ends of the fuse holder check that or try tuner cleaner before inserting the fuse.could also be a short in the fuse holder.
On a 95 dodge intrepid what would cause the interior lights to stay on? They only go out when the fuse for the radio is taken out.
There is a switch on the dash that adjust the glowing of the dash lights. This switch maybe turned all the way up and may need to be readjusted,
The dash board cluster has stopped functioning as well as the radio and interior light,no blown fuses
body control module and these are common issues with chrysler products.
2answers
How do you input the code in our radio of our chrysler neon
see here  for the Neon 2001 - 2008
http://www.torbaycarstereo.co.uk/chrysler_p05091610ab.html
or if not try here
http://www.radio-code.co.uk/code-entry-help-Chrysler.htm
My 1996 dodge neon wouldn't start...mechanic told me it was the battery...replaced battery still after sitting for too long won't start took it to another mechanc...not the alternator. he said that a wire...
try and check for small lighting...under hood light, trunk light...maybe those turn off buttons could be stuck in. Or, maybe you have map lights under the rear view mirror on?
CT STEALTH
1helpful
2answers
2001 dodge neon radio
Also had no radio but flashing bass/treble indicator lights. As suggested by another post, I disconnected neg. batt. cable and pulled the "interior cluster" fuses, re-set them and then reconnected batt. cable. This fixed the radio.
2helpful
The internal lights of my Chrysler Neon car is always on.
I had the same problem a few months ago. If you locate the pressure switches on the door frames (which are pushed in as the doors are closed to switch off the lights) you will see that the centre of each switch is adjustable. Working on each of the doors, if you carefully pull the centre of the switch out slightly and then close the door the switch should then adjust itself and create the contact needed to switch off the interior lights. I hope this helps. David W
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
