Comdial 7260 Incoming number displayed not the name.
When we receive an incoming phone call the number of the caller is displayed instead of the name. What do we need to do to have the name displayed instead of the number?
We have three phones in our office. The other two display the name. Mine is the only one that displays the number instead of the name.We have three phones in our office. The other two display the name. Mine is the only one that displays the number instead of the name.
You can't post conmments that contain an email address.
Do name/number display on any other phones on that line?
If that is your only phone, try borrowing another with working call display from a friend or neighbor. If another phone doesn't display caller info, call your phone company - most charge extra to provide caller number ( and in some cases, another extra to add the name). Even if the features are included in your rate, it's possible they weren't turned on correctly.
Your Panasonic may also have a setting to show name or number - depending on the display size, you may have to pick one or the other.
Finally, some phones do not support exactly the same caller ID info that the phone company sends - I have seen some which displayed number instead of names and no name, just because the two pieces of equipment did not agree on the standard. Try your Panasonic on someone else's line with working Caller ID.
Answering an Incoming Call When you receive a phone call, the incoming call screen opens. If you have previously saved the caller's number in People , the caller's name and number are displayed. If the caller's number is not saved in People , the caller's number is displayed.
Drag to round circle and phone icon to the right to answer the call.
When ending a call, drag the circle with the phone icon to the left to cancel or end a call.
Also attache is a manual, check page 25
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888.In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
First try adjusting the ringer volume up. Also, you need to be in the ring group to have your phone ring on an incoming call. If you are not in the ring group, you'lll need to contact your local tech service.
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
