Question about Javelin Systems Inc (81160083W98) PC Desktop
Old Dell Omniplex pci communication serial port needs driver
I have an embroidery machine that I want to connect to an older Dell omnilex i70 (I think that's the series).  It has  2 serial ports in the rear.  One is designated for the monitor and the other is not.  The connection for the embroidery/sewing machine is with a double serial port cable that came with the Singer.  One end is connected directly to the computer (the spare port in the back) and the other end connects to a convertor box. The embroidery/sewing machine connects directly from the serial port to a USB in the rear of the machine.
My problem is that when I connect the serial cable into the open port in the rear of the machine, it gives me a yellow exclamation mark when I view the Device Manager.  When I try to fix it, it wants the driver.
I went on the Dell site to see if I could find the PCI communications driver for this port, but the machine is beyond the warranty period and it won't help me.
This machine is using XP OS and everything else is working properly-including the USB/Serial cable from the embroidery machine to the computer.
Oh, this machine is NOT connected to the internet and never will be so I need to download the driver to a flash drive then to the computer.
Can you tell me where I can find the driver for this? And when I do, and download to the flash drive, where do I put it in the system files so that the Device Manager can find it to reinstall?
Thank you in advance for any assistance.
  • Javelin Syst... Master
  • 4,338 Answers
The PCI communications is for your Dial-up modem. It is probably set to use the only serial port that you mention. The other port is your VGA port.
You can remove or disable the modem to free up your serial port. Since you do not use the modem to dial up to the Internet, You can physically remove it from the PC. Restart your PC and the port will be freed up for your sewing appliance.
When you remove the modem make sure that the power is off.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 21, 2009
    Novelist:
  • 166 Answers
Go to the Dell support website http://support.dell.com/support/downloads/
Put in your service tag # (it is usually located on a little barcode sticker on the back of your machine). It does not matter if your machine is out of warranty or not. This is one of the reasons I like DELL. DELL has drivers for their machines that go back 10 years or more. I have never had a problem getting them from the website. When you see the downloads that you need download the ones that say driver. You may have to download the chipset driver also. When you do download the drivers and it asks you for the filename to save it as I find that it helps to add a name to the dell #'s to describe the driver so that it looks something like R264710video. Once you download them and transfer them to your computer they should install themself in the correct location (you just have to double-click on the .exe file and answer the prompts (if any)). Let us know if this helps.
SOURCE:
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
How can I purchase a hard drive for a Bernina 180 Embroidery Machine. The authorized Bernina Repair man can install it?
Don't think they offer that nor was it an option. They have a serial interface to download or upload designs to or from the machine's embroidery option. Check out a USB to Serial onverter and connect the PC to the machne. I used a Dynex brand cable and it worked. Use Bernina'a Artlink software (it;s free) and connect that way. Very easy to use.
Feb 25, 2011 | Bernina Artista 180
I was just given a 180e embroidery machine ( I am a total novice) and I am not sure how to connect the dongle and get designs that are in my computer. Thank you so much cat
I am not exactly sure of this particular model. But the dongle should just plug into the computers port on the back of the computer.
Jan 19, 2011 | Bernina Artista 180
USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
Jun 23, 2010 | Bernina Artista 180
Trying to connect a Bernina 165 to a Dell computer running Windows XP Pro in order to use machine embroidery. All of the four ports (COM 1, 2, 3 or 4) say the port is engaged. Previously, with an older...
Please check the Bernina website software upgrades for a solution. I use XP Home and have no problem but there was a software upgrade download for my Artlink version and also for the security key for the Bernina Designer 4.0 to install to make it work.
Aug 12, 2009 | Bernina Artista 170
Customizer's reader/writer 2000 quit working
I am having the same problem with the Customizer 2000. Worked before but now I get a "communication error". I'm thinking the problem is with the cable. You mentioned you got a new cable. Can you tell me what kind you got and where you got it? I don't know what else could fix the problem. Thanks for your help. I wish I could help you.
Jun 06, 2009 | Janome Memory Craft 9000 Computerized...
HAVE LAPTOP AND BERNINA 185 EMBROIDERY SET UP HOW CAN I MAKE CORRECT CONNECTIONS WITH USB PORTS, ETC.
You must purchase a Serial (port) to USB (port) adapter. I got mine at Radio Shack. Hope this helps
Jan 07, 2009 | Bernina Artista 180
I am trying to hook up my singer embroidery machine converter box to my laptop. I think I have to have a specific type of driver on my computer for this, can you help?
Dear Dawn528,
The driver is included with your PSW software and will load automatically when you install the software.
You will need a serial/usb adapter to connect from the machine serial port to your laptop usb port. This will come with a seperate driver that you nee to install.
Good luck
Dec 21, 2008 | Singer Quantum XL-6000 Computerized Sewing...
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Javelin Systems Inc (81160083W98) PC Desktop Logo
539 people viewed this question
Top Javelin Systems Inc Computers & Internet Experts
Alun Cox
Are you a Javelin Systems Inc Computer and Internet Expert? Answer questions, earn points and help others
