I'm having a problem with my pop-up camper lights. When I turn on the running lights on the tow vehicle, all lights on the camper turn on brightly, brakes, turn signals, the whole nine yards. I tried two different tow vehicles with the same result. I just replaced the wire from the tow-vehicle to the camper, so it shouldn't be that.
FIRST, make sure white wire of camper is grounded to the frame of tow-vehicle. Temporarily use a jumper-cable frame-to-frame. Then apply 12volts individually to each of the three circuits to the camper. Assuming a 4-wire flat connector -- brown wire is for marker lamps; yellow is left brake/turn; green is right brake/turn
I had a similar problem and busted my head trying to figure it out. my neighbor said to check the lights i had a double filament bulb where i should have had a single messed me up for days but now all is good
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4 way tow vehicle side.
4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5 way tow vehicle side.
5 way trailer side.
6 Way System, Rectangle Plug
3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6 way tow vehicle side.
6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7 way RV flat blade tow vehicle side.
7 way RV flat blade trailer side.
