Question about BigHorn 4 Bike Carrier
1992 v6 petrol izusu bighorn.sparkplugs coverd in oil.how do i fix problem
  • Yakima Master
  • 10,528 Answers
Valve stem seals is a place to start
Posted on Jan 09, 2014
SOURCE:
Isuzu bighorn 1995 V6 petrol,auto works in all forward gears, but doesn't reverse.Feel it engage but just doesn't go back. Have changed tranny filter and trans oil but still no luck
ok did you look at the color of the fluid? if you fluid is some what dark the clutches for the reverse maybe burn out or the reverse ban may be broken so if i was you i would take it to the professionals ok
Nov 05, 2015 | Isuzu Trooper Cars & Trucks
Isuzu bighorn3.0cc
would the catilic converter on a 1992 izusu bighorn would that make the truck loose power at 40kms hour.as the light comes on about then
Apr 25, 2014 | 2001 Isuzu Trooper
Spark plug location
how can i locate number 1 spark plug for my Isuzu bighorn petrol V6 engine
Jan 04, 2014 | 2011 Hero Honda Pleasure 100
How do I replace the fuel pump on a 3.0 v6 92 Pajero
DianPenChe petrol pump in the tank, you want to change you must remove the fuel tank in the oil pump and there are two issue: 1 in the oil pump assembly, oil pump's called shell connected in, 4 s shops and rich in method, fast, simple, inexpensive, 500 piece count in the conscience. 2 in the pump core, open the cover of the oil pump assembly, is in the inside of the pump (pump), the full package instead of 100 pieces. Oil pump is bad bad pump core, assembly is a bigger plastic shell as a support, the pump core is fixed to live.
autodiagnostic tool
Mar 25, 2013 | 1992 Mitsubishi Pajero
1992 mitsubishi pajero 3.0 V6 PETROL.how many litres of engine oi
Engine what????
Oil = 4.5 Litres or 1 Imperial gallon
Mar 10, 2010 | 1992 Mitsubishi Montero
I have an isuzu bighorn 1992 3.2ltr v6, and it did not come with an owners manual, what oil (grade) should i use for the diff, transmission etc
hi if it is an automatic you need to use dexron2 for transmision, if it is a manual you need 10w30 and for the diff 80w90 for the rear hope this helped
Feb 13, 2010 | 1992 Isuzu Trooper
Check engine light
Remove the battery terminal connectors for 5 minutes and replace back. This should do the trick.
rate my solution please.
Sep 23, 2009 | 1999 Isuzu Trooper
Autobox only working in first and reverse
Get ready to change your transmission. I just had to and it had the same issues.
Mar 09, 2009 | 1998 Isuzu Trooper
Bighorn 3.2 V6 Petrol - Transmission
does it feel like its in 2 gears at once and dragging. what was the original trans problem(why you changed it)
Aug 24, 2008 | 1993 Isuzu Trooper
BigHorn 4 Bike Carrier Logo
42 people viewed this question
Top Yakima Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Yakima Vehicle Part and Accessory Expert? Answer questions, earn points and help others
