BigHorn 4 Bike Carrier Logo
Ged Blackbourn Posted on Jan 02, 2014
Oil on spark plugs - BigHorn 4 Bike Carrier
hossamnada
Level 1:
  • Contributor 35 Answers
  • Posted on Jan 13, 2014
hossamnada
Contributor
Level 1:
Answers
35
Questions
0
Helped
7757
Points
77
If the spark plugs sink in oil so you need to change the rubber for the cam cover, if the oil come from inside the engine which is up-normal you must find it in water too, so you need to open the engine and see what is the problem.
CHANGING SPARK PLUGS ON A 2002 LINCOLN LS
Generally in a spark plug is 60000 kilometers, if fuel is bad need in early, remove the spark plug, such as for auburn or rust color, spark plug showed normal; Such as stained with oil, shows that the spark plug gap imbalance or too much oil, high tension line short circuit or open circuit; Such as black smoke, spark plug type cold wrong or mixture is thick, the oil is up; Such as the top between the electrode and sediment, when for the oily sediment, shows that the cylinder into the oil has nothing to do with the spark plug, when the black sediment, spark plug carbon deposition and bypass, when grey sediments, is a gasoline additive covered electrode lead to lack of fire; If serious erosion, such as the scar at the top, with black pattern, electrode melt, showed that the spark plug is damaged.
hope help you -auto diagnostic tool
Oil on Spark Plugs
If the oil is on the outside of the spark plugs, you could have leaking valve cover seals or gaskets.
1990 honda accord dx/ oil on spark plugs
i put gasket maker around the spark plug gaskets cause honda are notorious for oil leaks on the spark plugs
2answers
My mower started making smoke and then stop working?
SOUNDS LIKE THE OIL HAS FLODDED THE SPARK PLUG. REMOVE THE SPARK PLUG AND CLEAN IT USEING A WIRE BRUSH AND SOME BREAK PARTS CLEANER. THEN DROP SOME OF THE OIL OUT. YOU MAY HAVE PUT TOO MUCH IN THE ENGINE. THE SMOKING WAS CAUSED BY THE OIL BEEING BURNED BY THE SPARK PLUG. SOME HOW OIL GOT IN THERE. TRY CLEANING THE INSIDE OF THE SPARK PLUG OPENING WITH SOME CARB CLEANER. PUT THE SPARK PLUG BACK IN AND TRY TO START IT. REMEMBER IF THE SPARK PLUG IS FOULED UP, IT WILL RUN POORLY OR NOT AT ALL.
Jul 25, 2012 • Garden
1helpful
Oil leak! I am getting oil on the spark plug wire leads right at the spark plug. When I ride it leaks eniugh to drip when stopped from the oill that has sparyed back out of these two locations. Left front...
pull the spark plug tubes out and inspect.you probably have cam chains that are loose.if this is the case see gadgets fix-it page for info for getting extenders for tensioners.
hope this helps,mike
1helpful
2answers
1999 VULCAN HAS OIL LEAKING AROUND THE SPARK PLUG DOWN A WEEP HOLE AND OUT THE BACK OF THE CYLINDER HEAD. WHAT IS CAUSING BUILD UP OF OIL IN THE SPARK PLUG WELL? REAR CYLINDER RIGHT SIDE PLUG
hi, sounds like the oil seal in the rocker cover has failed, remove the rocker cover and you will see a rubber seal, this seals the oil inside the cover, however when the seal fails around the spark plug hole, oil leaks into spark plug well and out of weep hole.
4helpful
2answers
Changed the spark plugs and the old ones were covered in oil
i'm guessing that your car is a 4-cylinder. this is common for inline 4-cylinder engines. since the spark plug holes usually go through the valve cover, the valve cover gasket will leak and collect in the spark plug holes. to fix this you will have to replace the valve cover gasket.
2answers
How do i change spark plugs
get your tools out and learn on the job
2helpful
Oil in 1 1997 chrysler lhs spark plug tube
although I am not familiar with this particular engine my son's Mazda Miata had oil in the plug holes and it only required a new valve cover gasket to fix it.
16helpful
4answers
Oil around spark plugs on 1992 honda accord
Yes the oil can cause the car to lose spark, the oil leak could be caused by the valve cover gaskets around the spark openings, but 9 times out of 10 it is the spark plug tube "O" rings. The top of the valve train comes off of the head, the "O" rings are between the two halves, that will fix the oil leak.
Top Yakima Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Yakima Vehicle Part and Accessory Expert? Answer questions, earn points and help others
