SOURCE: Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
SOURCE: i dont have a hdmi on my mach speed trio steath g2 tablet can i hook up to the to watch nexflix
You should look at a Google Chromecast.
This is an HDMI device, that you can stream from your android to the ChromeCast connected to your TV.
They are actually quite cheap to purchase.
Then you use your tablet to control it.
It should also work with Netflix.
SOURCE: Can you do a screenshot on the Trio Stealth G2 9.7 Tablet?
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
